Is this gonna be a problem? (nitrous related)
Old 04-14-2008, 02:52 PM
porksoda's Avatar
Default Is this gonna be a problem? (nitrous related)
I ran all my lines and mounted the solenoids for my wet nitrous setup. I put the nozzle in and put it right in front of the IAT sensor. Is this gonna be a problem when the nitrous hits the sensor? Here is a pic so you can get an idea of where I put the nozzle. The yellow arrow points to where I put the nozzle.
Old 04-14-2008, 04:33 PM
Formula96's Avatar
thats where i put mine... But i faced the nozzle toward the filter, maybe thats why i blew a head gasket. hmm
Old 04-14-2008, 04:53 PM
grn95t/a's Avatar
just a guess, but i would say yes
Old 04-14-2008, 05:06 PM
Prototype007's Avatar
Seems to me where spray is so cold as it exits the nozzle it would cause the car to run rich since its sensing a cold air charge.
Old 04-14-2008, 05:59 PM
grn95t/a's Avatar
thats what i was thinking too? and maybe set a code and ses light too?
Old 04-15-2008, 12:07 AM
96lt1m6's Avatar
You will be fine with that set up,if you are concerned with the sensor getting frostbite you can relocate the sensor closer to the air filter
Old 04-15-2008, 01:39 AM
porksoda's Avatar
Well I really don't want to risk the car going rich because of the sensor getting cold. I had just completely forgot about the sensor when I pulled off the elbow and started drilling. I guess I can use this as an excuse to get a polished Trickflow elbow.
Old 04-15-2008, 07:14 AM
green95vert's Avatar
That's exactly where mine's at since 7/07ish and I haven't moved it yet. I felt stupid after I got it hooked up cause I didn't even think about the IAT being right there. Haven't had the SES light come or any codes set or any troubles at all with it, like a few said, it might be running a little rich. I'd rather run rich than lean, especially on the bottle. It's held up just fine for a couple 100 shot runs and a few 50 shot runs also.
Old 04-15-2008, 08:27 AM
Skidd's Avatar
Mounted mine in the same spot, little more fuel wont hurt while spraying.
Old 04-16-2008, 10:59 AM
porksoda's Avatar
Well maybe I won't get the metal elbow.
Quick Reply: Is this gonna be a problem? (nitrous related)
