Procharger FMU - Advice Needed!
Old 04-18-2008, 07:06 PM
Masochist's Avatar
Default Procharger FMU - Advice Needed!
So I've got the old Procharger mechanical FMU on my car and part of me thinks that it could be partially responsible for my car running as rich as it does.
I'm not sure what to do for an upgrade however, what would even replace it? It's a '95 so I can't do too much with the computer but Tunercat is an option thankfully.
Any advice on this would be greatly appreciated.
Old 04-18-2008, 09:22 PM
MEAN LT1's Avatar
Ditch the fmu and get some bigger injectors. What it sounds like though is that you need to get her tuned and get her leaned out some. What size injectors do you have in there now?
Old 04-18-2008, 11:07 PM
Masochist's Avatar
46# lol - do larger injectors take the place of the FMU?
Old 04-18-2008, 11:12 PM
MEAN LT1's Avatar
How much boost are you running?. Your stock regulator plus bigger injectors will replace your fmu. The fmu helps out if your running small injectors. But in your case I would get rid of it.
Old 04-18-2008, 11:31 PM
Masochist's Avatar
10#'s currently, but planning to amp it up once I get a bigger blower. Is there no worthwhile upgrade to a stock fuel regulator?
Old 04-19-2008, 06:51 AM
SCTA's Avatar
I've seen your car around. Where in Utah are you? I ran 42's with my procharger, no fmu, and tuned it with tunercat. It ran awesome just like that. Get rid of that fmu and tune it properly. You will be much happier.
Old 04-19-2008, 12:18 PM
Funkybird's Avatar
Ditch the fmu. Its a bandaid for stock injectors.
Old 04-19-2008, 12:22 PM
96capricemgr's Avatar
Why do you think the stock computer is a handicap?? It can work quite well.
Old 04-19-2008, 08:01 PM
subarubill96's Avatar
get 60's and a tune and call it a day
Quick Reply: Procharger FMU - Advice Needed!
