3.73 or 4.11
3.73 or 4.11
wanted a recommendation on what gears to put in my 93 trans am my tranny guy said ther is 2.73 in it now it is a a4 pretty stock but will be doing a motor. i mainly just blast it around town and i dont care about mileage.im worried i wont nottice a difference going with 3.73 thanks
also what is the weakest part in the 10 bolt i know it pretty much sucks but i would rather the majority of my money in the motor. i would like to replace the weakest partput
For a Daily Driver 2.73 to 3.73 will give you 36% more RPM per MPH, that's a good size change and you will see a difference, 4.10 is 50% more RPM per MPH and is pretty drastic of a change. It depends on what you want to end up with. Personally I put a 3.42 in my A4 with stock 16 inch rims and can easily fishtail through 1st and 2nd than calms down in 3rd so am very happy as it does what I wanted. If you are thinking about racing, or strip, or with a cam that needs higher RPM in the higher gears then it's a different story.
