Draglites on the Rear, Brake clearance..
Old 04-19-2008, 06:41 AM
the_merv's Avatar
Default Draglites on the Rear, Brake clearance..
I just got a set of 15x8's, 5.5" BS to go on the back of my Camaro. The guy said the Fronts cleared without a problem, they are 15X4's. I have the LS1 Front Brakes and the Rims came off of a '00 Z28.
My question is will I have to grind on the Stock LT1 Back Calipers to fit the Rims? I have a 1/4" Spacer if I need it.
Old 04-19-2008, 07:33 AM
Smokinlt1's Avatar
I'm not running spacers and brakes are over 70% worn and I still had to grind the caliper. Whenever I finally get new brakes I'll have to grind the calipers some more since I don't want to run spacers with stock wheel studs. Oh yeah, I'm running the Draglites 15x8 5.5bs as well.
Old 04-19-2008, 07:35 AM
Razor_Blade's Avatar
I'm running a 5/16 spacer with no grinding.
Old 04-19-2008, 08:03 AM
Ken95Z28's Avatar
Yes you will need to grind the fins off of the rear, I'm running 15x10 7.5bs Draglites. I would avoid running the spacers on the rear if all possible.
Old 04-19-2008, 08:47 AM
94nitrousedLT1's Avatar
I would not run spacers on the back of the car. You will have to grind down the cooling fins.
Old 04-19-2008, 09:37 AM
the_merv's Avatar
K.. Thanks guys.
Old 04-19-2008, 10:02 AM
Vicious95Z28's Avatar
So you can grind the front a touch an get away from running the spacer? I've thought about that to keep the wheel tucked in.
Old 04-20-2008, 03:47 AM
the_merv's Avatar
I had to use the 1/4" Spacer for the Front(LS1 Brakes), the Backs fit perfect with the Grinding I did.
Old 04-20-2008, 12:23 PM
SS MPSTR's Avatar
Absolutely. No spacers on the rears. I run them on the fronts, but I also put on huge studs.
Quick Reply: Draglites on the Rear, Brake clearance..
