Need stock head specs ASAP....
Trying to find out the stock specs on my 95 LT1 camaro heads for tuning purposes. I have been finding anything from 53.5cc to 58.22cc. Even the LT1 newbie FAQ goes grom saying 54, to saying 58.
With the rebuild kit I ordered for my motor, the pistons would land me at 10.4:1 with a 58.22cc head. The variation from 54-58 can put me anywhere from 10.3-11.2:1 (if im doing my math right).... Anywayz any help would be great.
Block and Basics
Displacement: 350 cubic inches, 5733 cubic centimeters, 5.7 liters
Block Material: Cast Iron
Main Bearings: 2-Bolt Centers and Ends (The Corvette LT1/LT4 had 4-bolt mains)
Stroke: 3.48"
Bore: 4.00"
Compression Ratio: 10.4:1
Combustion Chambers: 54 cubic centimeters
Factory Redline Rating: 5700 Rotations Per Minute
Bottom End
Piston Material: (10159437) Eutectic Aluminum/Silicon Alloy
Connecting Rod Material: (10108688) Powdered Metal
Crankshaft Material: (12556307) Cast Iron
Top End and Valvetrain
Cylinder Heads: (10168448) Cast Aluminum, 2 valves per cylinder/16 valves total, ~212 CFM flow (Impala SS and Caprice heads were made of cast iron*)
Valve Diameter: (intake- 10241743, exhaust- 12550909) 1.94 intake, 1.50 exhaust
Valve Overlap: 41*
Valvesprings: (10206040) 85 lbs, seated
Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
Rocker Arms: (10089648) 1.5:1 Stamped Steel
Timing Chain: (10128485) Powdered metal butt link
Stroke: 3.48"
Bore: 4.00"
Bottom End
Valve Overlap: 41*
I measured mine from a 93 Camaro as 53 CC.
The replacement gaskets from Fel Pro I seem to remember are .041" and if the heads are on the car what piston depth are you using? The true amount of deck and gasket thickness will probably alter your calculation more than the difference of cc in the head.
Good luck
Good luck
