Possible Optispark, LT1 newbie here.
my dad bought a 307 Caprice i guess it has an optispark, it turns over but doesnt start up, the mechinac told my dad it was an "ignition control module" is that another name for an optispark?
If so are they hard to replace, and expensive?
It's not another name for the optispark. The igintion control module (ICM) is connected with the coil in the same bracket located on the driver-side head. It's like $170 from GM I think but you can find them at the junk-yard and it takes maybe 5min to take out the old one and put in the new one.
http://shbox.com/1/ICM_cooling.jpg
replaced, but wasnt the problem...jiggled the ground for the fuse box in the engine bay, and car turned on. The surrounding plastic for the ground was completely cracked, and started smoking. We are going to buy another fuse block, but wonder why its smokin....
