What Are The Best Head/cam Package For A 2k Budget Or Even 1400
in in the market for heads and cam but only looking to spend 1400 if poss. maybe 2000.00. i'd like to see what numbers i can get myself into with info provideded by you guys and the price of course. please send me a link if poss. also
thank alot
www.notasponsor.com
www.notapsonsor.net
is there anyother packages beside these also
thank alot
www.notasponsor.com
www.notapsonsor.net
are you going to do all the work yourself? you may need to raise the budget a little for all the little things you run into if you know what i mean. those two are probably your best choices that are out there. i do know of a set of heads and cam in the forsale section for 1000 dollars i think, guy claims he made upwards of 400 horsepower with them.
Going with a nice head/cam package will run you close to $2k. When you consider in bolts, gaskets, rockers, studs, guideplates, pushrods, intake manifold porting, throttle body, injectors, and other random things it exceeds $3k real quick. If you go used it will be cheaper of course but hard to keep everything under a 2k budget I would imagine assuming you do it right.
Assuming the heads come with springs and retainers, you still need;
Rockers $270 (Comp Pro Magnum)
4130 Pushrods $90
Lifters $200-405 (Stock replacement VS Morels)
Guides $20
Studs $35 (ARP)
Gaskets $200+ (I like Felpro sets then add MrGasket Head and Percy's header gaskets)
Larger Injectors $200-$400
Tune ($150-550) You get what you pay for here.
Throttle body and manifold porting are optional.
I'd suggest at least having the manifold ported to match the heads.
My H/C Shopping list
http://www.cardomain.com/ride/2297151/4
