XE, XE-high lift, XE-R, XFI Cam Lobes. Who knows the difference?
Looking for a good detailed explanation of the following Comp Cam lobe profiles:
XE
XE-high lift
XE-R
XFI
I want to understand which are the easiest and which are the hardest to control the valves. Which tend to provide the most power and which are brutal on valvetrain. Any other additional info is appreciated.
Thanks guys.
XE
XE-high lift
XE-R
XFI
Thanks guys.
I find Comp to be of very little use regarding things like this cause its in their interest to provide safe or conservitive information. The promised that 26918's would control my valves which turned out to be total BS.
I have a lot of faith in the gearheads on this forum to provide detailed answers relating to my questions.
XE
XE-high lift
XE-R
XFI
Thanks guys.
XE
XE-high lift
XE-R
XFI
Thanks guys.
2) Ask your cam designer. If that is to be you, as it appears, you are probably SOL.
How familiar are you with the definitions of 'Cam Velocity' 'Cam Intensity', 'Acceleration' and 'Jerk' ? If not, see 2) above.
Good luck.
XE-R is an lsx lobe so that doesn't apply.
I'de try to get ahold of someone knowledgeable at comp if that's even possible. You're probably going to get alot of people guessing in here so take it for what its worth. Goin by .050 to .200 duration they are in this order.
XE, XFI, XE high lift. There's more to lobe agressiveness than .050 to .200 duration though, but this should give you a rough estimate.
From what I know about the XFI cam it is designed for late model FI motors and is designed to be used with 1:6 RR and "bee hive" springs. The info I read when I got mine said the ramps are faster vs a cam for a "carb" motor.
I do not have any "graph" info for the comparisons you ask regarding lobes, LSA, etc.
I will post my cam card info and maybe others who have a XE, XE-R can do the same and you can make comparisons. With that said that info would be available on the COMP website.
Comments like that are not needed. For the guys that ask why people dislike them, that post is a good example.
Everyone want's to be a moderator, but so few are chosen!
I attempted to be a bit subtle, but you guys evidently don't want that so, to be blunt, I don't think the OP has a clue about valvetrains, or any of the physics that apply to them. Agree or disagree on that point, 96capricemgr?
I think the OP should grace another provider (eg. AI) with his business. That would be a hell of a lot better for him than trying to spec his own cam and valvetrain bits and save him a ton of money in the end. He needs to spread the wealth around. I'm not sure AI would be happy with the deal in the end, however, especially if they read all of the OP's posts and responses.
You know about the 5% (or 2% or 3%) rule in sales, don't you? It applies in this case big time.
Jon Bauer
(Bret Bauer's father, if anyone missed it)
PS: Just between us (don't tell the mods), I'm not supposed to mention that on here because he is not a sponsor and is banned from posting, but you brought it up 96capricemgr. Thank you for doing so.
PS#2: Oh $h*t, I just plugged a non-sponsor (AI) in my post! Here come da' judge!
JB
Last edited by Old SStroker; 05-01-2008 at 09:59 PM. Reason: To clarify the subtle reference to certain posters.
WRD1972
I would get my cousin in here (since he did grind his own cams in the 70's and did not use someone elses lobe designs) but only comp can really answer your question, since they made the changes for each series.
Oh, no one missed that, 96capricemgr, unless they fell off the turninp truck very recently.
Where did I say I wanted to spec my own cam? Did not.
Did I claim to have a clue about valvetrains? No.
Did I ask for subtle? No
Did I rip Brett in this thread or any other? No
Did I even mention AI? No.
WTF is you problem. Maybe I should have called GM to ask about rebuilding my motor according to your logic.
I am trying to educate myself about cam lobes, their characteristics and requirements for my own benefit and curiosity. I asked a simple question. You are providing nothing useful but smack. I did nothing to rattle your cage and cause your pissy panties to get wadded up like this. If you want to turn this into a Brett ripping thread, just let me know now. I know many board members that would die to come to that party.
For the time being. Please take your turnip truck, velocity, intensity, and Jerk (how fitting) and
Thanks to the guys that are providing useful comments.
I am trying to educate myself about cam lobes, their characteristics and requirements for my own benefit and curiosity. I asked a simple question. You are providing nothing useful but smack. I did nothing to rattle your cage and cause your pissy panties to get wadded up like this. If you want to turn this into a Brett ripping thread, just let me know now. I know many board members that would die to come that party.
LMFAO
Guys, FOCUS
I dont want this to become a LE or BRE ripping thread.
Let please stick to the original question.
XE
XE-high lift
XE-R
XFI
XE
XE-high lift
XE-R
XFI
Guys, FOCUS
XE
XE-high lift
XE-R
XFI
XE
XE-high lift
XE-R
XFI
Go online to Comp Cams' Master Lobe Profile Catalog. It's a 3.2 meg .pdf download. Look thru it for descriptions and specs on the lobe series you mentioned. Digest that information for a while. There is a good chance you will be able to answer many of your own questions. How about coming back and posting your own answers. I'm sure folks will chime in if they agree/disagree. It will give them at least a starting point.
I thought everyone with a cam question like this looked at the catalogs first. My mistake, I guess.
If I seemed(!) harsh on you, I did not think you were prepared enough for the real answers. No offense intended. Not knowing something, even the basics, is not a sin. Not trying to educate yourself by your own efforts but rather asking to be spoon-fed info which you may not understand is, IMO, a mortal sin.
You need to put some effort into you own education of this topic. If you are unwilling to do that, I am unwilling to spoon-feed you.
"Give a man a fish and..." You know the rest.
Jon
FWIW, 'Jerk' is the rate of change of 'acceleration', which is the rate of change of 'velocity' which is the rate of change of 'distance' (or lift). All of these are extremely important to understanding valvetrains.
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
Your intake lobe is 3192.
Subract the .200 duration from .050 duration. Generally speaking the smaller the number the more agreesive the lobe is.Smaller # = faster, more agressive ramps that are opening and closing faster. And Like I said the XE-R is an LSx lobe so you can't run it.
The high lift versions that have lobe numbers in the 3100's are more aggressive over the nose and will require more spring or less rpm.
