fuel pressure issues and no start
Car has 60psi at crank then drops to 40psi then down to 20psi and wont start I cant smell fuel at the motor. I do hear the in line come on, So I thought the walbo intank went out so I swapped that with no change..
Ideas?
Ideas?
First of all 60 is really high at cranking. How fast does it bleed off? There are three regular culprits to fuel pressure bleed off.
1. Check ball in the pump - new pump needed
2. Faulty diaphragm in the fuel pressure regulator - check this by pulling off the vacuum line to the fpr and look and smell for fuel, if present the fpr is bad.
3. Leaky injectors - pull up the rail and prime the pump at koeo, if any fuel drips out, the injector is bad.
