LS7 fuel injectors
They will not fit a LT1 Engine, they are 42 lb/hr I believe.
The Injector itself is skinnier about .5" taller, and uses a EVI-5 Connector. The LT1/LS1 F-bodies have a EVI-1 Connector. I'm currently using LS2 Injectors on my 402, they are identical to the LS7 Injectors, the difference is that they are rated ar 33.9 lbs/hr.
Couldn't you still run them Merv, if you got a slightly longer bolt (and the EVI-5 connectors spliced on) and put a washer or 2 under where the bolts go for the fuel rails? I believe quite a few people run the tall, newer style ones, on their LTx motors.
EV6 is what you're thinking about.
