LT1-early sbc swap
Block is basically the same, same motor mount holes you just need to reuse the brackets from the camaro. And you will have to do some trimming to get the distributor and air cleaner to fit. Probably more too, I'm sure someone will chime in with more info
Run a DIS system then. Crank trigger and the like. Might even be able to get away with the LT1's oil pump drive shaft if you make a plate to bolt in and plug the distributor hole.
If you are handy an alternative is to put an old style block and use the opti. Yes it can be done. Allows for an economical large displacement from 400 block, and large intake and use the modern electronic fuel injection for control.
There are a couple ways to do it, one is use a TPI distributor with opti guts another cleaner way is to make a different timing cover and mount opti upfront just like an LT1.
you know you could swap an lt quiet easy if you get on for the same year the harness would plug in and play alot easer you could even use the electric fp use a regulator and you could use your return line also this dist may clear i am not shure this is the system like battleship was talking about http://store.summitracing.com/partde...5&autoview=sku
I have never ridden in a smallblock with jsut a cam that ran as good as a ls1 with jsut a cam...
im saying why ditch the fuel injected lt1... for something less refined, and is the same damn thing (Lt1 is pretty much a SBC.)... If your going to go through the trouble of swappin junk around, then put a gen 3 in it.
but an LT1 is ~$700, an L$X is a great motor ju$t what i$ the word I am looking for? I hear all the time how inde$tructable L$X are: but like all SBC they aren't. A friend has a Z06 8 psi, meth, and pro tune it lasted 3,000 miles.
Now that is not indestructable and he made a mere 530 rwhp at dyno in a 6 speed sooo I will stay with junk, and my $$ in my pocket.
Because a carb motor is easier and cheaper to upgrade. No need to tune a computer to get things all dialed in right. Lots of people can work MAGIC with a carb on a motor as well.
I do not see Carb'd motors as cheaper to upgrade, but we all have our preferances
Well, I have a Carb Guru as a friend, and he's all self taught and only 29. He's been working on cars since he was about 13, and his first car was an 88 Escort which he made RWD and slapped a 283 in lol
At any rate, I mean cheaper as in you can find better parts than what you generally have by just checking out other cars. Like we stumbled across some 56cc heads he had in his garage for a SBC, and he had a pretty big Lunati cam laying around from another build.
that would be nice if you could, as for dumping the lt1, the car is just a rolling chassis, that's it, i have the motor and tranny already that was going in a 87 trans am but i'm kinda having a change or heart and wanting to go w/ a different body
Any updates on this? I'm thinking of doing this to a rolling chassis 93' Z28 thats been in my yard for a couple years, thinking of making it a dirt track car since its pretty beat. That and I think it would so beyond awesome to have a 4th gen that has an SBC with straight out exhaust sidepipes. Not sure if my neighbors will feel the same way lol.
