*PICS* 6,000 mile old opti, toasted.
Old 05-15-2008, 02:59 PM
LT1MAN's Avatar
Default *PICS* 6,000 mile old opti, toasted.
i'm hoping someone can tell my why this full price acdelco opti spark took a **** on me after 6,000 miles. me or my mechanic don't know. it went in with the new motor.
Old 05-15-2008, 03:01 PM
Revelation Z28's Avatar
was it the low res signal?
look for rust under the second cap
Old 05-15-2008, 03:12 PM
Elliott's94Z's Avatar
Is that the stock opti spark? I haven't had to change mine YET and I am curious to know why I haven't seen anyone upgrade to the opti spak II conversion. Is is a costly upgrade and a big hassle? Don't mean to butt in on your thread bra..
Old 05-15-2008, 03:24 PM
LT1MAN's Avatar
Elliot, not the stock opti, but it is an "oem ac delco opti". my 383 went in with the newer style vented opti setup about 6,000 miles ago.
revelation, ill have to bring in my set of torx bits to get that cap off, ill check in the morning and post more pics.
Old 05-15-2008, 03:33 PM
Got ya..that really sucks..everytime I start my car I think to myself..Is today the day..
Old 05-15-2008, 05:27 PM
lt1 hawk's Avatar
I think the same thing to myself as well. For both the opti and the water pump. But I am picking up a new pump next week (to have just in case), got a good deal on it.
Old 05-15-2008, 06:13 PM
I put a EWP on..we will see how long it lasts..hoping a while considering I don't drive the car much.
Old 05-15-2008, 06:42 PM
lt1 hawk's Avatar
are there any real advantages to an EWP over the stock one?
Old 05-15-2008, 06:43 PM
BALLSS's Avatar
the rivets are one of the weaker parts of the Opti.
High RPM's are the typical reason rotors get lose. Might want to swap in a MSD rotor & cap. The MSD has screws holding the rotor. Put loc-tite on the threads
You said 'new" motor...
confirm pin on cam is not to long and pushing Opti.
Old 05-15-2008, 06:54 PM
Free's up some hp..I noticed it more top end. I've seen dyno charts with 5-9rwh and 10rwtq gains. Engine stays cooler especially in hot weather. Haven't seen mine go pass 185-190 deg. since the install. They are rated at 2500 hours which to me is good because I don't drive the car much.
Old 05-15-2008, 06:57 PM
check this page out..the guy has his dyno chart up..his is one of many I have seen and they all were about the same
http://www.projecttransam.com/projects9.asp
Old 05-15-2008, 08:25 PM
19mike84's Avatar
i just install an ewp and i love it too. it runs great
19mike84's Avatar
installed*
Old 05-15-2008, 09:51 PM
I like to hear that
Old 05-15-2008, 09:58 PM
stevema10631's Avatar
tell me about the opti problems the first 4 times my waterpumps failed this last time the timing cover seal failed and it filled with oil long live the opti spark
Old 05-16-2008, 12:33 AM
LT1Formula007's Avatar
Hope you get the car back together man!
I had to replace my water pump a while back and it lasted for about 5,000 miles and the front seal started leaking around the cover that bolts to it. Had to fix that and then the plastic flow valve on the hose going into the heater core started leaking. So I know how much of a PITA it can be to have to replace or redo a job over again. Good Luck!
James
Old 05-16-2008, 05:46 AM
Village Troll
SS RRR's Avatar
that opti only has 6K miles on it and the outside looks like that?
Old 05-16-2008, 06:30 AM
LT1MAN's Avatar
yea man i have some oil leaks, my timing cover leaked, the intake and the oil pan. i had those fixed but the pan still leaks some when i get on it.
Old 05-16-2008, 06:33 AM
LT1MAN's Avatar
hmmm, i see. everything is tight though. the dowel pin has been replaced with the correct length, the first one that was in there was too long but its gone.
Old 05-16-2008, 11:04 AM
projekt70chevelle's Avatar
What part of the opti does moisture tend to ruin?
Quick Reply: *PICS* 6,000 mile old opti, toasted.
