What weight oil for a LT1 with 132,000 miles?
1 Post
I'm running mobil one synthetic 5w30 right now, and someone told me that is too thin of an oil. Is that true? i need to seafoam the engine and then do an oil change. any recommendations?
~100 degree heat waves we get.
for reference GM recommends
atleast
6 Psi at 1000 rpm
18 Psi at 2000 rpm
26 Psi at 4000 rpm
if 5W30 keeps you above those specs there is no need to change to a thicker oil
mobil 1 is a thin oil but a good oil. the only reason people talk **** about mobil 1 is because they now use cheaper (for a lack of a better word) ingredients in their oil. it still is a good oil but there are better oils. royal purple would be one of those better oils, among others which im sure people will tell you about.
