Custom y-pipes w/cats
The Macs come with a Y-pipe that keep the Cats in the stock locations ( only way to be 100% leagal). They fit nice and are well made. We had one minor problem with the pass-side flange had a slight tweak that we had to fix, found this out after we had the stock exhaust off! and the pass header just bearing touched the brake booster. So too late to send back. But I've installed a few sets and this was the first time we had any issues. The Y-pipe bolts to the stock intermidiate pipe. You shouldn't need to do anything special.
Below is a link to an install.
http://www.97transam.com/headers.php
If you want something custom, Mufflex built my Y-pipe, LT headers into a 3" Y with cats into a 4" collector. Looks odd, but it does work great.
http://www.97transam.com/pampered-z/IMG_1134.jpg
I've worked on two cars, the car in the pics with those headers and a 847 cam and Loudmouth, compaerd to another 97 we did: Same cam nearly same convertors, but LE2 heads, long tunes, ORY ( after market exhaust, forget which one? ). 40-45 HP apart. So the Macs must be flowing pretty good.
I certainly did! I didn't like the look of it at all! The lines are wrapped individually with the heat reflective cloth. I went as far as to take it apart and re-sew it all back together so it's nice and tight, then fab'd an aluminum shield and also covered that with the self stick heat sheild as well.
