will these injectors fit my car
I like the racetronix injectors. I like them better than the SVO's I was running with my old setup. The ones I have now are flow matched and that is probably why they worked better for me than the SVO's. I think that Racetronix injectors are Delphi. I also think that GM uses Delphi injectors on stock application. They have to warranty those for 100,000 miles these days. That is if GM uses Delphi injectors. I dunno. Would have to do a search.
Well, those are actually the Delphi / Lucas disc type injectors. The "normal" injectors are pintle type. You need to Google for more info, too much to be discussed here. I have run both with no problems for either. I am currently running the 42 Delphi disc injectors, and they work just fine.
AFA flow matching, most claim that the manufacturing processes are now so refined that it is not required. IDK, just repeating what I have read elsewhere.
