$5400 on a bathroom towel and more to buy
I blew a head gasket and decided to add a few extras while it's apart. I am going to have the block bored and decked, crank turned if needed and balanced with forged rods and Mahle Powerpack pistons.
The heads are new castings with AI 200cc porting, mild custom AI hydraulic cam, 32lb Racetronix injectors, 54mm AS&M throttle body, Comp 7/16" 1.6 rockers and 1" polylocks, ARP studs, TFS guideplates, Cloyes 9-3145 timing set, GM lifters, Melling select oil pump, MSC cap and rotor, Mcleod twin disk clutch and billet flywheel, Impala .029 headgaskets. I got a good deal on some LT4 valve covers so I had to spend a little on some bling too.
I'm hoping my 10 bolt lasts at least till the clutch and motor are broken in.
My stock ones cleared with some modifying. I see no problem here.
De javu! When I lost my head gasket I went on a similar spending spree.
- MSD Probillet opti - returned it for a AC Delco to fix a high rpm miss (though I'm not so sure that was the problem)
- MSD coil - returned for a AC Delco coil from an Escalade (Again, it may not have been the problem, but I have another issue as well).
- LTCC - for once I get everything worked out with the stock ignition.
- '03 cobra injectors (39#/h)
- billet aluminum valve covers... ebay special (though I REALLY thought about those black LT4 covers... nice!)
- billet aluminum oil cap... it's pretty.
- billet aluminum dip stick... matches my oil cap
- billet aluminum monoblade... to match my dip stick
- comp Pro Mags, 7/16", ARP studs, Isky guidplates, and SmithBrother pushrods... fat ones.
Do EVERYTHING you want to do now... build it right the first time and you'll be MUCH happier.
But I'd kiss that 10-bolt goodbye.
