What is the best oil pump for my 1994 Z28?
Old 05-26-2008, 10:29 PM
sweet-94z28's Avatar
Default What is the best oil pump for my 1994 Z28?
I am pulling my pan next weekend because I think the oil sump screen has crap plugging it. I wanna put a new pump in there while I am there. I am gonna do the sump and screen thing as well. I want 65-75 pounds at WOT and about 30-40 at idle. What would be the best setup? Anything else to keep in mind as well would be good because I have never attempted this myself. I had my one co-worker take it off before and reseal it, but it needs sealed up again, so what all do I need for the ENTIRE job?
Old 05-27-2008, 07:19 AM
Would the Melling high pressure, stock volume pump be OK. Its not like I'm racing it.
Old 05-27-2008, 10:16 AM
halucinator's Avatar
I would personally think a High volume stock pressure pump would do good. You will have to replace the stock oil pressure spring if you want to go high pressure.
Old 05-27-2008, 10:54 PM
you can't do a high volume pump on a stock pan though
Old 05-27-2008, 10:59 PM
Revelation Z28's Avatar
id say a stocker or ported stocker with the GM "white" spring for a little extra pressure.
Old 05-27-2008, 11:25 PM
Get a better pan then.
Quick Reply: What is the best oil pump for my 1994 Z28?
