True duals w/not enough ground clearance
Old 06-01-2008, 02:04 PM
1MeanGreenZ28's Avatar
Default True duals w/not enough ground clearance
I have a 1996 z28 with Pacesetter LT's w/ dynomax oval race mufflers. I have problems with this setup scraping the ground. I love the sound of dynomax mufflers, but need to change. I dont want the bullets but thought about the round dynomax race mufflers. I dont want a catback system either. I need some mufflers which gives me some ground clearance. Just need some advice on what mufflers to use and the way to set them up under the car. No Flowmaster mufflers! Thanks.
Pics of the setup:
Old 06-01-2008, 02:08 PM
IronOutlaw's Avatar
i think edelbrock makes some nice mufflers that are only 3 inches thick if im not mistaken.
Old 06-01-2008, 02:11 PM
camaro-94-z28's Avatar
just cut off the mufflers
Old 06-01-2008, 02:59 PM
Got to have some mufflers man! It would be pretty loud without them.
Old 06-01-2008, 03:31 PM
Sinister95Z's Avatar
That is one of the main reasons I went with Sweet Thunder chambered mufflers. Get some of the Stainless Steel versions and you will be good to go.
Old 06-01-2008, 04:12 PM
Where did you buy them from?
Old 06-01-2008, 06:24 PM
z28camaross's Avatar
is there a big performance difference between a 2 1/2'' x pipe and a 3'' x pipe????
Old 06-01-2008, 07:06 PM
flyinZ's Avatar
I went with 3" and an X-pipe and you can barely see mine. I went with the Flowtech mufflers, only 4" thick, but I also massaged my floorpan as well...It helps.
Old 06-01-2008, 07:27 PM
Here you go :
http://www.sweet-thunder.com/chambered_general.html
They sound awesome on a true dual LT1. I have them behind some Pacesetter long tubes, dual 3" with an x-pipe and turn downs before the axle. You will not be disapointed!
Old 06-01-2008, 10:37 PM
lt1 hawk's Avatar
Sinister, do you have sound clips? I am researching a TD setup on mine...
Old 06-02-2008, 01:44 PM
MYSTIC-1SC's Avatar
I don't know how well the dynomax ultra flow round muffler will work if you already have clearance issues with the ovals because i believe the 3" ultra flow round muffler has an overall diameter of 6". The current mufflers you have are 4 1/2 inches tall
Old 06-02-2008, 02:58 PM
No sound clips right now. I will have some soon though as the cam swap is almost complete. They will sound even better with a CC503...
Old 06-02-2008, 03:19 PM
OutlawZ's Avatar
I have true duals and I have 4 INCH oval pipe and have way more ground clearance than that.....
So I say invest in an oval setup from spintech... They make all the pipe... It ain't cheap but it's better than having .5" of GC...... Heres a pic of EXHAUSTZILLA.....
Old 06-02-2008, 03:42 PM
ABA383's Avatar
I think someone mentioned the Edelbrocks..I run the 3" SDT 304s and they are only 3 5/8" thick and tuck up very nicely...and they are great sounding and not too loud...
--Alan
Old 06-03-2008, 11:15 AM
MYSTIC-1SC's Avatar
very nice setup outlawz
Old 06-03-2008, 12:02 PM
OutlawZ's Avatar
Thanks... but to the OP you have options...... A good exhaust guy that can get those muffs tucked, some adhesive heat shielding BEFORE you start, and oval spintech tubing..... I don't know if other companies besides spintech make oval muffs so there you might be screwed...... but spintech's rock anyways...
Old 06-03-2008, 12:30 PM
LT1MAN's Avatar
if you like the way it sounds with the ones you have now, ever thought about just taking them over the axle and out the back?
Old 06-03-2008, 06:49 PM
jarendt31's Avatar
Dont go with spintechs then because my clearance is about the same
Old 06-04-2008, 11:36 AM
Dadic 78's Avatar
You could always go oldskool, and hit up the cherry bombs!!!
Old 06-04-2008, 10:07 PM
I know it needs to be changed, but still dont know what to do. I have a lot of ideas thanks to everyones advice and opinions. If anybody has more advice on what to do, just chime in and let me know. Thanks everyone for help!
Quick Reply: True duals w/not enough ground clearance
