My S60 is here
My S60 is here
Just got it this morning:
Just need to get it painted and put in. The bad part is its going to be probably two weeks before I can do that.
I can't wait to get it in. I'm busy right now so I hope in 2-3 weeks I will have time to get it in. I have seen were people have ran same time with there S60 as they did with there 10 bolt.
Here is some threads talking about weight difference and track times between the two:
https://ls1tech.com/forums/showthrea...ght=weight+s60
I also got mine for around $300 less than a 9-inch.
you sure the 9 inch your looking at, isn't just housing and axles? The last time I checked mosers 9 inch housing and axles was cheaper than a 12 bolt, but by the time you add the 3rd member in, it is more expensive.
The 60 is $1135
Which is cheaper than the 12 Bolt
But the 12 bolt is more expensive than the 9".
In turn the 60 is as well.
Yes after reading and researching I went with the S60. From what I understand it takes less power to turn than a 12 bolt or 9 inch just heavier. If I am getting something that is going to add more weight why not be at the back of the car.
