95 LT1 misfire
95 LT1 misfire
I have a 95 lt1 that has a bad misfire. I have been through the plugs and wires a hundred times. It only happens when the engine is warm and at WOT it clears up. Sometimes it happens at idle. It feels like a couple cylinders are dropping. It has no codes. Any help would be greatly appreciated.
Best suggestion is buy a cable load datamaster it allows 20 free collects. You will see more what is going on and Datamaster is no dummy once you try it you will buy it.
Also next would be Tunercat to adjust the correction you find from datamaster. Cable and both tools are well worth it allows you to fix and adjust almost anything on your car.
High RPM backfire can be BAD my first thought is this is likely not good..
