OBDII swap into OBDI car
Old 06-09-2008, 06:52 AM
jarretthise's Avatar
Default OBDII swap into OBDI car
i took a 97 SS lt1 6 spd driveline and stuck it into my 94 car...there are a few wires that are diff on the harnesses so i need some help on which ones are different......it is a 97 motor harness and 94 interior linked together.....i just need to know what needs to be changed on the harness to make it work......PLEASE HELP
Old 06-09-2008, 08:05 AM
BattleShip's Avatar
I did NOT search here since I assumed you already did, but I saw a detailed writeup either on Impala Forum or LT1 Tech. Look there the thread was thorough and accurate.
Old 06-10-2008, 07:07 PM
bump....please help
Old 06-10-2008, 07:32 PM
BattleShip's Avatar
Rather than wait a day and a half your internet also has a search capability
Try
http://www.dogpile.com/
type in lt1 obdII to obdI
look at results I bet you will find
"94/95 LT1-Edit
Do you have a 96 LT1 and want to use a 94/95 PCM to run it? Yes you can! It works fine. Here is a link to what you have to do: OBDII to OBDI Conversion.htm "
Read and you will see the details that I spoke of...or you could visit the sites I suggested
Good luck
Old 06-10-2008, 09:26 PM
TwoFast4Lv's Avatar
You can actually use the 94 engine harness on your 97 engine and every thing will be great
There will be a few sensors that do not have wires(Crank sensor, one check vavle) but every thing will be great
We converted my car to OBD-II in 01
Old 06-10-2008, 11:37 PM
yeah i dont have the harness anymore....i need a 94 m6 harness,the car was a4 i swapped to a manual..i know it will work i just have to find the 94 harness now..lol
Old 06-11-2008, 03:18 AM
phirepower's Avatar
try Hawks third gen parts they'll have it
Old 06-11-2008, 08:31 AM
TwoFast4Lv's Avatar
I 'think' the OBD-II harness will plug in and work fine. Give it a shot
Old 06-11-2008, 09:11 AM
BattleShip's Avatar
Personally I prefer to avoid the "I think" and follow the link that I provided...but it is your choice, someone will follow the link and post the how to do it and be considered a genius...so wait a few days!
