my fans are not coming on when they are sposed to?
okay i found out that my primary and secondary are not comming on when they are sposed to,i let the car idle till about 235 degrees and neither fan ever came on, is there a sensor that activates the fans or do i need to reprogram?
The temp sensor in the water pump tells the computer what temp the motor is and the PCM then turns on the fans. So it could be bad, but you'd probably be getting bad gas mileage too. Could also be the fan relay (cheaper to test) not working anymore, giving them power. Swap a relay out somewhere else and try it in the fan's spot. Otherwise, to test the motors, just jump 12v from the battery to the positive on the fans (Don't forget to ground, and ground the proper wire too, 3 wires on yours (I believe) for being 2 speed fans).
I checked the relays and they are both working,the fans are 1 speed, two speed are for 95 an d up i believe. I turned the ac on and only the primary goes on,and when it reaches 226 and higher no fans come on,
Well oddly the secondary + primary I thought comes on when the AC is on...
I'm no PCM guru (since I have an ECM) but I'd think it'd be something screwed with the PCM then. Or the sensor in the water pump. That's only $8~ and much cheaper than getting a new PCM
GLT1, take a look at this schematic from shbox site its' a 1995 but I believe similar to the '93 " http://shbox.com/1/fan_schematic_1995.jpg " I believe the '93 one speed fans uses the top setup of two relays, later year two speed fan setups have three fan relays. With stock settings your primary fan relay should pick with a ground from the PCM at 225* F (107 C) and run fan 1 at high speed, the secondary should pick at 235* F (113 C) and run fan 2 at high speed. Also the A/C pressure sensor will tell the PCM to pick the primary fan if the AC is functioning. If you are loosing both fans at 226 with A/C running then as Formula stated it could be the temp sensor in the wp or the PCM is killing one or both fan run circuits, or your +12v to run fans from the fusable link +12v distribution block on the pass fender is opening under high current. You can attach 2 thin 5-6 inch wires to the pick side pins of the relays. reinsert the relays, turn on ignition and ground the wires one at a time or both at once to check relays, fans, wiring and voltage sources. relay D pin 2 and relay 3 pin 5 to ground will run the respective fan. I only recommend this if you are comfortable with reading schematics or working around live circuits.
Well,i might run the fans through the fuse box,but i want to see if i can fix this to factory specs.Other than the water pump sensor,what is the sensor in charge of activating the funs based on the temp gauge on the dash?
Yea, it'll hurt mileage since the computer doesn't know wth is going on with outside temp. The one guy on here is a great example. His PCM thought it was 30 below and was just DUMPING in fuel. Mind you, they all die in different ways, and yours seems to be maybe just malfunctioning right now heh Who knows really, unless you hook up a scanner and see what it's at.
i had my scanner hooked up to it and it was dead on accurate pretty much the needle was at 210 and the scanner said the car was at 208. it has a cylinder misfire for sure tho cuz it needs new plugs and wires im hoping thats all it is. but are there any other temp sensors on a car besides on the waterpump? and sorry didnt mean to hi-jack thread just having same problems.
gotta remember that when your in town idling even with the fans on there isnt alot of air moving through the radiator. cruising on the highway though. lost o air through it.
If you think it's clocked chck under the bumper for paper or plastic.
You can make your own fan switch if you know how to wire things up. I'm sure a diagram on ShoBox.
