Oil pressure gauge dead
I blew my motor and had a new (used) motor put in. The shop that did it said they put a new sending unit on the motor when they put it in, so it is the gauge that is the problem. Is this possible? it is stuck way high and doesnt move at all, if that makes a difference. Is their a way to fix the gauge without replacing the whole cluster? thanks
No I havent, Im pulling the engine soon for a LS1 swap, but will be keeping my LT1 gauges, I just want to know if I need to change out the cluster or not. How would I go about checking the sender to see if its corrected?
