oil pump drive gear
Ever stop to think guys are talking about the gear on the cam?
I am sure some guys have gotten creative and redone the stock syle drive that bolts into the lifter valley but the overwhelming majority of us are using stock ones, and overwhelming majority I would call an understatement.
Folks cause themselves untold hassles trying to reinvent wheels that work just fine, save yourself some hassle and use a stocker with maybe a safety plate added as flame mentioned above.
LS1TECH Sponsor
Theoretically it would be the driven gear..... or what we refer to as the distributor gear, even though someone got the bright idea to cut the distributor off the top.
The fact is that many race style billet roller cams should use a bronze gear, but the "stub" shaft is a different diameter than GM distributors. GM used a 0.491" or 0.500" shaft on distributors. LT1 shafts are smaller, so a bushing could be made to use one of the larger aftermarket gears. Comp even makes a composite one that may be a nice addition.
With a stock style cam there is no real need to change it.
re
we used a comp polymer gear and made a bushing to fit inside the id of the polymer gear for the oil pump drive... we also have a lathe in our garage. works great, btw we did this becuse a buddy put a billet cam with the billet gear on the stock oil drive and wondred why it didn't have oil pressure a few months later.
LS1TECH Sponsor
It has nothing to do with cams being junk......
A steel billet cam will require a bronze or polymer gear. These will ruin the stock oil pump drive.
Extreme performance applications, using very high spring pressures & aggressive solid roller profiles will not live on a cast core camshaft. There are also some combination cores with the steel core cam that has the cast gear mated to it. These allow the stock oil pump gear, but these cams do not work in all applications.
Now in reference to the original post.... a worn gear may often fail on a new camshaft due to the new gears meshing differently. It is always best to change the gear unless the engine is very low mileage.
Thanks that is what i think has happend in my case. We are going to try a new gear with it and see what happens. And for anyone that is reading this that is thinking about a cam swap I would recommend putting in a new gear. It will save you a headache and alot of money for a cheap part! It cost me a bottom end but hey you live you learn!
The EverWear gear plays nicely with the stock oilpump drive. All that needs to be done, if you really want to reinvent the wheel suppose you could get one and adapt it to the oilpump drive as well. Many companies have switched to this as it solves the reliability issues like those you experianced.
