k-member with stock a-arms
on most yes, u can use the stock arms. i am using a pa racing kmember with my stock arms. i recommend that you rebuild both your upper and lower arms while your there doing the kmember. i used the poly bushing kit and new ball joints on both the uppers and lowers. really helps if you plan on removing the sway bar.
