Injector questions
If you could get a scan done and find out what your duty cycle pct is. Then u will know what to get and now just guessing if i remember right the stock injectors are 24lbs. The ones u have still may be enough but if they are not adequate anymore i will take a wild guess and say get some 32lbs ones. And if your gonna add more power latter you might want to plan ahead and get even larger ones. Ive changed injectors 3 times with my current ones being 65lbs high impedance ones. (Its been a while since i thought about cars so please bare with me if any of this is just a little off) If you dc pct is around 75pct or higher its time to get bigger injectors. I hope this helps
Micah
Micah
