underdrive pulleys and other bolt on questions
ok. so im trying to finish my car as a full bolt on. i have lt's, ory, catback, cutout, k&n cai, 160* t-stat, tb bypass, 1LE elbow, no air or egr, stb, and i think thats about it. i plan on finishing the suspension. i was looking at the march underdrive pulley set. are they a good set? and i was also looking at an electric wp. my only concern is how long do they typically last? and is meziere or csr a better brand?
Underdrive pullies are not particularly worthwhile. On engines where the waterpump is belt driven they make a nice difference because the pump is underdriven and the waterpump is power hungry.
Far as TXFORMULA's statement about pullies not being worthwhile unless you have an electric, well he is thoroughly confused.
Actually with a stock cammed car and stock idle I would worry about the effects of UD pulley and the added alternator load, could have charging issues leading you to OD the alternator.
I mentioned stock cammed specifically because a larger cam usually gets a higher idle which would help avoid charging issues.
Personally I think the only way UD pullies are useful is if the car sees sustained hiogh rpm use and you are overheating the PS or the like. I also think that if you are going to do it you would be better off to put a new smaller diameter damper which would likely be ligher and the weight will be closer to center which would mean it has more potential for power gains.
thanks for all the input guys. i will definitely be checking out the 1.7 rockers. i dont plan on a cam anytime soon. i will look into the asp pulley set and meziere hd ewp since it seems to do well. the only thing about the csi, csr or whatever its called is i probably drive that much in a year and a half. i need a good tune as well
I DO have a set of asp pulleys that i would sell you cheap... the crank pulley has some dings on it from smacking the hub on... it is the 23% underdrive kit from asp i can even give you the belt (it might work for you)... 65 shipped which is half of what i paid for it...
consist of crank poulley, alt. pulley and belt... the kit from asp does not include the belt...
i also have a used lt4 spring kit that i would sell you for an extra 25 dollars... kit consist of lt4 springs reatainer, seats and locks... i used this kit for 1800 miles and they worked fine with my 1.6 rr's but i'm putting a cam in and i went with the 10308-1 spring kit from crane...
For the record here is my suspension list.
Springs:
- Sam Strano lowering springs
- Every mount related to springs / suspension when doing the springs and shocks was replaced with MOOG and OEM parts where and when applicable
- New poly bumper stops
- 99 thru 04 cobra rear spring isolators (gives more of a drop)
Rear Suspension:
- Poly / Roto single on car adjustable panhard bar
- Poly / Roto single on car adjustable LCA’s
- Bolt on LCA relocation brackets (now welded on)
- Powdered Coated OEM upper panhard bar
- UMI upgraded rear sway bar
- UMI billet rear sway bar mounts
- UMI rear sway bar axle mounts
- Energy suspension rear sway shorter end links
- UMI full length adjustable torque arm
- UMI transmission mount relocation cross memeber (Automatic Transmission) takes Torque Arm off tailshaft
- Bilstein HD shocks
- Stainless Steel brakelines (J&M WS6 Store)
Front Suspension:
- UMI upgraded front sway bar
- UMI billet front sway bar mounts
- Blaine Fab powder coated front heavy duty sway bar mounts
- Energy Suspension front sway links (need to go shorter link)
- UMI 2 point Strut Tower Brace
- UMI 2 point Weld In Subframe Connectors
- Sam Strano Brake Master Cylinder brace
- UMI tunnel mounted drive shaft safety loop
- UMI front lower a-arms delrin / rod (single adjustable tubular)
- UMI front upper a-arm mounts non-adjustable delrin
- UMI road race k-member
- UMI Delrin steering member inserts.
Springs:
Rear Suspension:
Front Suspension:
I agree with underdrive pulleys, especially the alternator one being pretty useless. The only reason I have one for the crank is it was free. I also decided since the motor is front internally balanced and rear externally, and that my motor is sacrificial, I don’t run a harmonic balancer, only an aluminum underdrive on the front. It cuts rotating weight more than cuts losses on the belt accessories. The alternator spinning slower has never been an issue. An underdrive plus a balancer I bet does nothing measureable in the 1/4.
Village Troll
The alternator issue depends on what kind of driving is done. I had one on mine when they first came out. No O/D pulley and a lot of stop/go traffic and short trips. Battery was dead w/in 6 months. Put O/D pulley on and never had an issue after that. Lots of stop/go, and from what I recall, especially automatics may have charging issues if no alt. O/D pulley is used.
