crank pulley
crank pulley
does a stock hormonic balancer fit an after market pully? i went to slp parts an was thinking bout buying an underdrive pulley from there but i didnt see an hormonic balancer with it
i bought a crank pulley while back...its set up that the stock pulley is on top of the aftermarket one...so it stilll has its balance...and you will need a new belt ....its says what number belt to get
^ what he said. most aftermarket underdrive pulleys work with a stock balancer, but also you may have to get a smaller/larger alternator pulley because it will alter your voltage a bit. Don't quote me on that but my friend had that issue
