What auto trans used in 93 Z28s?
Old 06-30-2008, 09:53 PM
fergymoto's Avatar
Default What auto trans used in 93 Z28s?
Hey guys got a quick question. What auto transmission was used in 1993 model Z28s? Need a solid 100% sure answer. If you do not know don't add confusion to the issue. Thanks!
Old 06-30-2008, 09:55 PM
infinitebird's Avatar
The 700r4.
It's basically the same as the 4l60e except everything is mechanical.
Old 06-30-2008, 09:57 PM
hashtagBMW
Speed Density's Avatar
Originally Posted by infinitebird
The 700r4.
And they are turds
Old 06-30-2008, 09:59 PM
fergymoto's Avatar
Thanks I suspected it was the 700R4 but wanted to make sure of it.
joshprescotttttt5's Avatar
i just got done dealing with this issue lol
did a v6 to v8 conversion using a 93 z28 parts car.
assumed it had a 4l60e in it but after i tore it apart to rebuilt it
turned out to be a 700r4.
some say all 93 have 700r4's and some say just early 93's do.
easy way to tell is if there is a cable on the throttle body linkage besides
the throttle cable and cruise control. should have 3 cables.
the third one goes the transmission on the passanger side.
if it has that then it deff. has a 700r4
Old 06-30-2008, 10:01 PM
LS1Silverado05's Avatar
4L60 .. Basically a 4L60E without electronic controls... Maybe a 4L60=700R4 ?..
Old 06-30-2008, 10:02 PM
19mike84's Avatar
yes i believe its a 4l60. at least from what i have read in tech articles. its very similar to the 700r4
Old 06-30-2008, 10:03 PM
fergymoto's Avatar
I can't check. I was looking at buying a 93 Z with a missing transmission. Looking at it on the internet that is. It's too far away to just go look at for the heck of it. I have a 4L60E here but I was certain 93s didn't run them.
Old 06-30-2008, 10:04 PM
From the speed density guys
Driveline The 93 used the 4L60 transmission which was controlled by a TV cable attached to the throttle body. The 94+ cars used the 4L60E which was electronically controlled, and had no TV cable provision. Because of this, the 93 had a slightly different throttle body than the 94+ cars.
Old 06-30-2008, 10:34 PM
1badzee's Avatar
I have the 700r4.. It's not a turd. Actually a great overdrive transmission when built right.
Old 06-30-2008, 11:11 PM
1SLO6's Avatar
its a 4L60......100% sure..........
Old 06-30-2008, 11:15 PM
hashtagBMW
4l60/700r same difference
Old 07-01-2008, 10:13 PM
slingshot928's Avatar
Who else has the best first gear ratio..3.06, lighting up the tires in first is always fun...my transmission is great, and i like the tv cable adjustment instead of the electronic, less **** to break and to tune. The 93 transmission is technically called the 4L60 without the e, a couple of people told me that it is a 700R4 with a reverse valve body, that is why trying to find a core is very hard. It was used in the 92-93 vettes, and the 93 camaros.
Old 07-02-2008, 10:08 AM
Crows93Z's Avatar
700r4 isn't the same as the 4L60. 700r4's do not have an electronically controlled speedometer, whereas the 4L60 does, which is the transmission in 1993's.
Old 07-02-2008, 11:59 AM
blackz93's Avatar
Yes they do. I have one out of a 91 RS in my 93. Definitely has a VSS on it.
