Intake leak causing oil pressure to be low?
Old 07-02-2008, 01:10 PM
95ZLT1's Avatar
Default Intake leak causing oil pressure to be low?
I've been having really low oil pressure in my car for awhile now and just recently discovered that i'm yet another victim of the LT1 intake leak. I was just wondering if the intake leak could cause the oil pressure to be low. When driving the gauge never goes above 30 psi regardless of rpms. It is really low at idle when warm. I'd say around 6-8 psi.
Old 07-02-2008, 01:15 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I don't think the oil in the lifter valley is under enough pressure that a leak would cause your pressure to be low, but I'm not an expert.
Old 07-02-2008, 01:24 PM
cnorton's Avatar
Oil in the lifter valley is not pressurized. A leaky manifold would not cause a drop in pressure.
Old 07-02-2008, 01:32 PM
95ZLT1's Avatar
Ok good to know. Hmmm now what the hell is causing it...lol
Old 07-02-2008, 01:44 PM
harner's Avatar
Oil pump?
Old 07-02-2008, 01:49 PM
95ZLT1's Avatar
I've heard from a lot of people that this is "normal" but i dont know. I'm kinda skeptical about that. Or just paranoid.
Old 07-02-2008, 02:15 PM
Badazz 97 TA's Avatar
i would hook a mechanical gauge to the engine and see for sure what the psi is. could be your sending unit which gives the info to the gauge. common problem with this engine. could be a weak oil pump.
Quick Reply: Intake leak causing oil pressure to be low?
