Need help with Cam swap.
Im just tring to make sure I get the right stuff and all that...
-COMP Cams Chevy Hi-Tech Pushrods 5/16 7.150
-COMP Cams SBChevy Pro Magnum Rockers - 7/16 Stud - 1.6 Ratio
-COMP Cams Redesigned #26918 Beehive™ Valve Springs
-ARP Pro Series Rocker Arm Stud Kit
I know I need Guide plates vause of the NSA RRs. Can someone help me out to pic the right stuff.
heres what im doing to mine....... this is pretty amazing .... with a Advanced Induction Heads intake and cam kit, i got a quote and its 3075.95 for rockers, springs, push-rods, exc. http://www.youtube.com/watch?v=ViB0oJOzfTE why dont you do a heads cam and intake kit?
Lifters - Depending on mileage. I would just use the Ls7 lifters.
TChain - Just a good idea since they are like $40.
Springs - Stockers won't hold up against anything other than stock really.
Balancer Bolt - Should always replace it when you pull off the crank hub and damper.
Gaskets for timing cover, water pump and intake.
Those are just a few...
