LT4 Hot Cam Kit What Should I Expect??
Old 07-06-2008, 07:55 AM
99Ls1fever's Avatar
Default LT4 Hot Cam Kit What Should I Expect??
Hi guys I am getting ready to install the LT4 Hot Cam Kit and I wanted to see what horsepower numbers I should be expecting to gain? I have C.A.I. and L.T.'s on it presently.. Thanks for the help
Old 07-06-2008, 08:10 AM
Badazz 97 TA's Avatar
automatic usually are around 325-330 range. manuals dyno a little higher with that cam. (both to the wheels)
Old 07-06-2008, 09:18 AM
96capricemgr's Avatar
Put better springs in, those springs are OK with LT4 hollow valves but LT1 valves are heavier.
Old 07-06-2008, 10:25 AM
99Ls1fever's Avatar
Thats it dam I was hoping for more. What do you think I would be at with the headers and CAI? Maybe I should pony up and get the 58mm throttle body from BBK and that will help. What do you think?
Old 07-06-2008, 10:26 AM
99Ls1fever's Avatar
So, the springs that come with the Hot Cam Kit suck? are they beehive or double spring?
Old 07-06-2008, 10:38 AM
lt170chevelle's Avatar
from what i have read the lt4 springs are good for only lt4 heads with the lighter valves.if you put them on standard lt1 heads with the solid valves can get a chance of valve float.and the cam is barely better than a stock lt1 cam. just has a tad more duration and lift.the rockers bump the lift up a little also.i always hear of complaints about the performance of the kit. it really is only a mild upgrade and cant really expect a huge increase in power.if you really want to put down some nice power you might want to get a bigger cam and springs...but just my opinion
Old 07-06-2008, 10:48 AM
but if you think about it a stock LT1 auto dynos around 260 to the wheels. with the hotcam and longtube headers its up to 325ish to the wheels. thats a 70+hp gain. i dropped a full second in the 1/4 mile with this cam.
Old 07-06-2008, 10:50 AM
Pretyflywiteguy's Avatar
lol another dissapointed consumer, thats a very common response. Those numbers are with supporting mods such as headers and CAI
Old 07-06-2008, 12:52 PM
registered user
ScreaminRedZ's Avatar
My car only made 230 to the wheels totally stock, so 330 would be a 100 hp gain for me, lol. I agree that bolt-ons and a hotcam will be right around there with the hotcam kit. With tires the car will run easy 12's (probably 12.6-12.7) full weight.
Old 07-06-2008, 01:47 PM
A full bolton car can top 300rwhp with springs and rockers on a stock cam. You are trying to pretend boltons do nothing. Even bolton b-bodies have topped 300rwhp.
Old 07-06-2008, 02:41 PM
luckyou03's Avatar
1. you can use the lt4 springs on lt1 head with no problem, I did for over 2 years like many other people have.
2. your thinking of the lt4 cam and he is asking about the lt4 hotcam. The stock cam being 201/207, .447/.459, 117 Lsa, upgrade to the hotcam which is 218/228, .525/.525 with 1.6 rr and 112lsa is more than just "tad more duration and lift."
3. "i always hear of complaints about the performance of the kit" Well the average hotcam user with see 330-340hp with this upgrade. Thats only 55-60hp over stock.
4. "if you really want to put down some nice power you might want to get a bigger cam and springs" With bigger springs and a bigger cam don't forget that you'll have cam surges, no low rpm power and revving your engine to 6600+
Old 07-06-2008, 02:59 PM
Yes you can put the LT4 springs on the LT1 heads, and most people who make such a poor decision are not going to be aware enough of what is going on to realize they lose performance to valve float with relatively few miles.
Point being, sometimes good reviews are the product of ignorance rather than a really good setup.
Old 07-06-2008, 04:33 PM
dre2013's Avatar
hotcam=disappointment IMO...i would go with at least a cc503. but since you already have the cam, i'd say just do allll the boltons on the car, stall(if auto),gear,ewp,LT's,tb,rockers,intake mani, etc etc etc...ive seen a few hotcams put down decent numbers, but most of the time they run high 12s or low 13s and put down around 330 at the wheels. this is all IMO, and based upon what ive seen btw.
Old 07-06-2008, 05:08 PM
99Ls1fever's Avatar
Thanks for the info man
Old 07-06-2008, 05:09 PM
99Ls1fever's Avatar
Whats your dyno numbers for your set up?
Old 07-06-2008, 05:11 PM
99Ls1fever's Avatar
Yea man it hurts I want good numbers , But I have a 99 too that does that for me
Old 07-06-2008, 05:13 PM
99Ls1fever's Avatar
At sea level or altitude cause up here with a stock LS1 I was running 336.8 hp 338.6 torque amd was running 14.3 at 103.13 mph... So If I do the LT4 kit I would like to hit 13's atleast
Old 07-06-2008, 05:14 PM
State69champ's Avatar
my buddys lt1 with a lt4 cam put down around 355wheel
Old 07-06-2008, 05:15 PM
99Ls1fever's Avatar
Dam man thanks for the great info, what wo you think the potiential power of that kit is with full bolt ons? hp wise? TB, LT'S, UNDERDRIVE PULLEY, CAI...
Old 07-06-2008, 05:17 PM
99Ls1fever's Avatar
Thanks for the soild info, it is a auto and has a fuddle 3800 stall, stock gears though
Quick Reply: LT4 Hot Cam Kit What Should I Expect??
