Cam Swap Nightmare!
Old 08-13-2008, 06:07 PM
whitez28133's Avatar
Default Cam Swap Nightmare!
Swapping out the cam today and found from what i can see the front cam bearing is wasted. any suggestions? can i do bearings with motor in car? is it common for the front one to go?
Old 08-13-2008, 06:16 PM
wrd1972's Avatar
Same exact thing happened to me, fron bearing was toast:
With a little creativity, you can replace the front bearing only. Impossible to do the rest which are most likely trash too. You can put the cam in and roll the dice, or pull the motor and rebuild.
Old 08-13-2008, 06:20 PM
how many miles was that at and what did you do?
Old 08-13-2008, 06:25 PM
96capricemgr's Avatar
The front bearing tends to wear more because it sees extra load from to the waterpump drive.
Old 08-13-2008, 06:50 PM
wrd1972's Avatar
65K miles.
Rebuilt the motor.
See signiture.
Mo faster now.
Old 08-13-2008, 10:02 PM
BigZee71's Avatar
I just did a cam swap on my 93 Z (122k) and my front bearing looked the same. I was worried at first but decided to go with it. The car still has 40psi at 210* at idle.
Old 08-14-2008, 12:07 AM
Fixxer99TA's Avatar
All that bearing is going to do is destroy the new cam you put in, I would pay close attention to any odd noises you might hear in the near future.
If I pulled my cam and my front bearing looked that bad, I would be pulling it out for a rebuild (more than likely a stroker).
Old 08-14-2008, 12:36 AM
TwoFast4Lv's Avatar
We seem to always have to replace the front cam bearing on LT1 cars. Even the fairly low mile ones
Old 08-14-2008, 02:37 AM
Counted Out's Avatar
Reading all of this makes my nervous.
The motor was rebuilt about ~10k ago according to the previous owner though - we will see.
Old 08-14-2008, 03:25 AM
Fixxer99TA's Avatar
You should be alright, unless your bearing looks like the one in the picture too
Old 08-14-2008, 06:37 AM
Internet Mechanic
BlackScreaminMachine's Avatar
If #1 is worn, the rest are too. You just cant see them. I would do this, pull the motor to refreshen or suck it up and slug the cam in there, worse comes to worse, you gotta rebuild again.
Old 08-14-2008, 06:21 PM
used a bore scope today and the only one messed up is the front one, slapping a new one in and finishing the swap this weekend!
Old 08-14-2008, 06:56 PM
Fixxer99TA's Avatar
Cool stuff, good for you that you caught it before it did more damage. And yes the front one is MUCH more prone to wear than any other, but most engines are the same way.
Be sure to post back your reactions when you fire that mother up
Old 08-14-2008, 10:57 PM
Ellis and I are in agreement that the front one is wear prone, I explained it by pointing out the additional load it sees from the WP drive.
If Ellis and I agree on something the debate should pretty much end there because you have the right answer already.
Old 08-14-2008, 11:13 PM
JoeliusZ28's Avatar
man i feel like an idiot i didnt even really check mine, but I would have noticed if it was worn bad. Just put a cam in a 90K mile motor and its been fine so far.
Old 08-20-2008, 10:34 PM
Fired it up on Tuesday and oh man was i impressed, sounds great not too choppy and has a great power characteristic all the way through! Bryan Herter is a great tuner, PCMforLess, Very satisfied. Got one problem the starter is seeming to get lazy at a hot start any thoughs, i think the starter is on its way out just kinda want some other opinions. Thanks again!!!
Old 08-21-2008, 08:45 AM
TwoFast4Lv's Avatar
LOL! We actually agree on more then meets the eye
Quick Reply: Cam Swap Nightmare!
