Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 08-29-2008, 11:05 PM   #1
TAHOE5.3's Avatar
Trader Rating: 0
Default carburated lt1 ???
Anyone switch there fuel injection to a carburator?? If so can you post some pics?? I've got a pretty unique piece I'll post some pics over this weekend.
TAHOE5.3 is offline   Reply With Quote
Old 08-30-2008, 12:24 AM   #2
1964 Ford Medium-Duty
My Garage
Formula350's Avatar
Trader Rating: 3
Send a message via ICQ to Formula350 Send a message via AIM to Formula350 Send a message via MSN to Formula350 Send a message via Yahoo to Formula350
Quote:
Nope, it's blasphemy!
Why do you want to? And the easiest way to do it would be get a GEN I motor, otherwise you have to keep the opti and computer for ignition.
__________________
1993 Firebird Formula A4 3.42 Torsen Posi
BBK 58mm TB | 24# SVO Inejctors | Stage 1½ 4L60 | Circle-D 2400 Stall | Vortec Alu Elbow
Afro Engineering CAI | SLP Catback Dual-Dual | LS1 Rear Brakes | Self Tuned Chip | !EGR !AIR
Planned: Polyurethane kit, IAT Relocation (closer to filter), Custom CAI.
"If your car doesn't run 12's, shorten the track" - Urban (x3Dfx Forum)
Formula350 is offline   Reply With Quote
Old 08-30-2008, 01:12 AM   #3
Trader Rating: 1
Ive done it.
Vic Jr intake modified for LT1 bolt patern
Pro Systems carb
MSD distributor
Car runs like a champ.
foggedz is offline   Reply With Quote
Old 08-30-2008, 01:44 AM   #4
Fixxer99TA's Avatar
Trader Rating: 5
Send a message via AIM to Fixxer99TA
Many have done it with great results, I am sure if you did a search you would find LOTS of info matching what your looking for.
__________________
- 2002 Ford F350 7.3L Lariat Stock/Stock Again/Plow (78k)
- 1995 Pontiac Firehawk #224 (Chameleon) Full Bolton/Cammed/Full Suspension (68k)
SOLD :
- 2002 Dodge Dakota 4.7L Not Cammed/3" Body Lift/Ramair hood/Painfully Stock (117k)
- 1999 Pontiac Trans Am (Black w/ ttops) Full Exhaust/Lid/Stock otherwise http://www.fquick.com/Fixxer777
Fixxer99TA is offline   Reply With Quote
Old 08-30-2008, 07:31 AM   #5
My Garage
Formula350's Avatar
Trader Rating: 3
Quote:
Originally Posted by foggedz View Post
Ive done it.
Pro Systems carb
MSD distributor
So you just made a block off plate for the opti hole?
Someone really should do a write up for this so it can be stickied
__________________
Old 08-30-2008, 09:52 AM   #6
Trader Rating: 2
I started to put one into a s10 project I had but never finished. Gm offers a opti block off plate. I have one sitting in my tool box.
All you need if a fuel source, gm intake or converted one and a distributor.
__________________
96 Z28 slowly working on it.
Skidd is offline   Reply With Quote
Old 08-30-2008, 11:02 AM   #7
Trader Rating: 1
Why do you want a carb?
Lots of guys have regretted doing this. The computer system really is cheap and easy to play with an amazingly flexible IF you are willing to learn and give it a chance.
__________________
96 Caprice, daily driver 190cc Advanced Induction package, 3400 Edge ProBuilt 4L60E,3.73, 11.93, 4100lbs.
95 Roadmaster wagon gets handme downs from the Caprice 15.5 the one night I took it out with stock exhaust even at that point
96capricemgr is offline   Reply With Quote
Old 08-30-2008, 11:25 AM   #8
slick1851's Avatar
Trader Rating: 0
Send a message via AIM to slick1851
Why the hell not? I if you know how to use a carb then its not a problem
FYI the fastest bolton LT1 runs a carb, but apperantly its record doesnt count for the bolton record since its a carb.
So its the fasted, bolton carbed LT1
slick1851 is offline   Reply With Quote
Old 08-30-2008, 11:36 AM   #9
Trader Rating: 1
Comments like mine are necessary because a LO of newbs think the computer is a complete roadblock. At the local track most of the old school carbed guys are amazed at the power/drivability/economy I get out of my car, not amazed enough to retrofit injection to their cars but still impressed.
__________________
Old 08-30-2008, 11:43 AM   #10
Trader Rating: 2
It is a roadblock in my case.My combo should make power upto 8k but I can only rev to 7k and the stock computer craps out
I have to make a decision on a aftermarket fuel management system or go carb and kill the computer stuff
__________________
96 camaro,LT4 solidroller 383,single plane intake with 90mm accufab tb,afr 210cc heads,th400 with t brake 5200 ati stall,26 inch et drags
10.62@127(1.43 60ft) 6.68@102 1/8th (all motor)
3325lb race weight
http://videos.streetfire.net/video/S...-DJ_133669.htm
Dave J is offline   Reply With Quote
Old 08-30-2008, 12:12 PM   #11
Kmaroman's Avatar
Trader Rating: 1
the guy i let work on my car did with his soons it runs 11s
__________________
1993 Z28 LT1 T56/M29 1.6 pro-form RRs, Fastchips, 160 t-stat, B&M short shift, Jegs opti, msd coil pack, msd super conductors, TB bypass,airfoil, all emmisions crap gone weighing in at 3100lbs
2000 S10 4.3L/4l60E DD no mods unless it breaks, and homemade CAI
Kmaroman is offline   Reply With Quote
Old 08-30-2008, 12:18 PM   #12
Trader Rating: 1
That is fine, there are going to be cases where it makes sense for one reason or another. Just I have seen way too many guys with MUCH closer to stock cars think a carb was the answer when all it would have been was a different set of troubles. Most guys who are comfortable with carburators write off the stock injection much too soon.
__________________
Old 08-30-2008, 12:19 PM   #13
Fixxer99TA's Avatar
Trader Rating: 5
That is quite the roadblock, and this might be the only reason I would go carbed. As 96 said, the PCM is pretty relyable and can be played with just as much as a carb. Many around can tune LT1s/LS1s great these days, but if you know a carb well enough to try it I dont see why not.
But I wouldent be throwing it out until I run out of RPM as described above.
__________________
SOLD :
Old 08-30-2008, 12:52 PM   #14
Trader Rating: 1
rpm really is the only limit of the rpm performance wise. all other hassles like injectors there are adapters for, MAFs there are lots of options. Boost is a hassle to tune on the single BAR setup but it is doable.
__________________
Old 08-30-2008, 01:28 PM   #15
TAHOE5.3's Avatar
Trader Rating: 0
i have a lt1 with 32 valve heads its a very rare piece the motor is about 85% finished No worries about removing the opti spark ignition there's all kinds of aftermarket block off pieces out there. As for ignition i have a msd distributor and a digital box. I mainly wanted to know what intakes were being used. My intake already has fuel injector bungs welded on to it. Since I'm eventually going to go with a turbo charged lt1 I will be using Big Stuff 3 to control the whole package.
Old 08-30-2008, 02:09 PM   #16
phirepower's Avatar
Trader Rating: 2
Send a message via AIM to phirepower
^ would you be refering to the LT5 zr1 motor?
__________________
phirepower is offline   Reply With Quote
Old 08-30-2008, 02:17 PM   #17
Trader Rating: 1
Yeah sounds more like an LT5 in which case I would think sheetmetal is about your only other intake option. If it is an LT1 with 32valve heads then they must be Arao Dominion 32 valve heads and again talking sheetmetal intake. Don't know if anyone ever got a car down the track with those but a few guys have tried to build cars around them.
__________________
Old 08-30-2008, 03:47 PM   #18
My Garage
Formula350's Avatar
Trader Rating: 3
I think he probably bought one of those rare set of 32V LTx heads.
Anyways, the 8K rpm reason isn't exactly a good reason to go carbed. You COULD use an aftermarket computer system.
There's a reason we went away from carbs, greater performance and much better fuel economy. Now yes, you can get a carbed LT1 to perform much better than a LT1, but as soon as you tune that LT1 you're going to be ahead of the carb.
Cost to convert vs cost to get a tune, getting a tune and being ahead is a much better choice!
__________________
Old 08-30-2008, 04:17 PM   #19
Trader Rating: 1
There are a lot more LT5s out there than running Dominion heads.
__________________
Old 08-30-2008, 07:55 PM   #20
Trader Rating: 0
It has been proven that if it is a race car and streetabilty is not a concern carbs still make more power in all the tests I've seen. Hot rob did a 6.0L put a carb on the fuel injected single plain and gained 15hp or so. There are other test that I've seen the same results. The old carbs did not meter fuel the way some of the new "modified" carbs do. That is why prosystems and other carb companies are able to get a bigger carb to run better then the old ones. Some of the carb companies have some good write ups on different test that have been proven. Not all myths are true when it comes to cars.
But if it is a street car that see's a little track time fuel injection is the way to go. It is so easy to change a couple numbers on the laptop and changing jets suck but at the same time my car when carbed. 8000+ rpm's here I come.
strokedz383 is offline   Reply With Quote
Tags
8k, 96, camaro, caprice, carb, carbed, carburated, carburation, carburator, convert, intake, lt1, rev, turbo, turbocharged
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
