!air?
Old 09-03-2008, 06:12 PM
NicksTAgt's Avatar
Default !air?
I'm gearing up for a cam swap and I wanted to delete my AIR system while im in there. I already have AS&M long tubes on the car, and they come with all of the emissions fittings. That said, I dont want to spend the money on new race headers. What would be the best route for doing this? I have looked around And I cannot find any sort of kit. I also hear that the AIR tubes to the headers are a very odd size..
Old 09-03-2008, 06:25 PM
Formula350's Avatar
Well, you could do what I did with my manifolds and just cut off the end of the air tube pipes so you can get the nut off, drop in a bolt and weld it up. Then screw it back in the manifold.
If yours don't fit on your headers, two options: Find the fittings that fit and weld them up, or weld up the headers directly.
Old 09-03-2008, 06:29 PM
AChotrod's Avatar
drop in a bolt and weld it closed. Thats how my slp mids are done.
Old 09-03-2008, 06:32 PM
NicksTAgt's Avatar
Sounds quick and easy, thanks for the advice. I'll make sure to post a video of it when in done.
Fixxer99TA's Avatar
+1 Weld em' up!
Old 09-03-2008, 08:29 PM
C_Rules's Avatar
+1 thats what i did to my AS&Ms
Old 09-03-2008, 08:30 PM
SoxXpupPeT's Avatar
i dont have a picture for some reason but i welded a flat plate over the entire hole. it worked real well
Old 09-04-2008, 06:30 AM
NicksTAgt's Avatar
I'd like to see that, were your headers coated though?
Old 09-04-2008, 07:09 AM
SoxXpupPeT's Avatar
just chrome mac mids. i plan on getting them jet hot coated tho. i know a took a picture i just cant find it
Edit: found the pics
i just took of the chorme with a zip wheel. tig welded it on and used the high heat paint to coat it so it wouldnt rust
Old 09-04-2008, 08:06 AM
NicksTAgt's Avatar
Looks good, I might go that route too.
Quick Reply: !air?
