Exhaust banging
Exhaust banging
Hi all quick question for you. I reciently had LT pacesetter's with ORY and Borla cat back installed on my 96 SS convertible. Problem is that it is knocking against the driver side floorboard during acceleration, or when I go over bumps etc...
Now I did not do the install, had local shop do it. I took it back to them and they said there really isnt anything they can do about it besides install some frame connectors to stop the frame from twisting because It is a convertible which is what is making the exhaust hit.
I am very novice at working on cars so I have no idea if that is right or not, but what can I do to stop it from banging. It sounds and feels like crap when it hits.
Thanks
Ok Crazy enough I thought I had done all the searching I could and couldnt find any info but here is one persons fix for the problem.
https://ls1tech.com/forums/lt1-lt4-modifications/982573-pacesetter-lt-y-pipe-fix.html
1996 Camaro Z28 SS convertible.
Thanks
if anything it sounds like they forgot some exhaust hangers if you say there was no knocking until the exhaust was installed, but ya, sub-frame connectors make a huge difference, i dont have a vert but i do have t-tops.
You either need a large hammer to make clearance so the header doesn't hit or new motor mounts to keep the motor from twisting as much.This is a very common problem with pacesetter headers.
Or if you have a welder, then weld an exhaust hanger where it's hitting the most.
Also a common upgrade for people with headers is the LT4 Knock Module, if you haven't done it, might not be a bad investment. Comes from a 1996 LT4 Vette M6 if you plan to goto the parts store. Otherwise it's in the NEWBIE FAQ in the Parts Numbers section I think under Ignition or Computers.
EDIT: Here it is, was still on page 1
https://ls1tech.com/forums/showthread.php?t=982573
I cut part the part where it bangs and beat it flat with a rubber mallet. A guy I used to work with cut it off then flipped it and welded it back it in place. Instead of using header wrap on headers I wrapped the fuel lines any where it was closer than an inch.
But if you knew that, NM
Your right about that but it's all I had to protect the fuels lines from the collectors at that moment and have been too cheap and lazy to do anything else with it. Figured it was better than not using anything at all.
My bangs to i put sub frame connectors in and it helped a little but didnt fix it so what i did was took an old valve spring cut it to fit in and it works pretty good its a temporary fix the real solution is put poly motor mounts in so the motor has no play in it
poly mounts fixed mine. after the lt and ypipe install i had the same banging. new polys and it was gone. sucked too, kicked myself in the ***. i was thinking i should do them when i was doing the header install. didn't! mistake! would have been much easier with the exhaust out. lol!
