Oil psi drops to 5 psi under hard braking - help
This weekend I drove about 200-250 miles completely problem free.
Last night I hit the brakes hard and noticed the oil psi guage drop very suddenly down to about 5 psi and the "check guages" light came on. I let off the brake and tapped the gas and the guage went back up to just under 40 psi.
This has never occured before. Car ran completely fine.
I drove a bit more, hit the brakes to test it again and oil psi guae dropped again. This time I hit the gas pedal before it had a chance to go so low. At idle oil psi sits at around 40 psi.
I drove to work and home problem free. While the engine was cold I was seeing about 45 psi - once warm just a bit under 40.
When I give it gas it goes up to 50-55 psi
I went out to test it again and same thing, hard braking and the psi drops.
Hard acceleration - psi does not drop.
Hard left turn - psi does not drop.
Hard right turn - psi does not drop.
Hard braking - psi drops????
I have a 96 Trans Am A4 w/ 113XXX miles
Basic mods - full exhaust, intake, a tune, ignition, mildly ported heads, 1.6 roller rockers, etc.
It's my daily driver. I don't beat the hell out of the car - just a nice daily driver to cruise in. It rarely sees over 4,000 rpm's. It has seen the track maybe 3-4 times for maybe a max of 12 runs?? I've had it for 1.5 years and oil psi has always been fine.
The original owner always ran royal purple oil - I have continued that.
Any idea what is going on? I find it really odd that oil psi would suddenly drop to 5 psi under hard braking?!?!!
Thank you for any help!
Stock oil pan? What's the psi during warm idle in gear? What rpm is your idle set at?
We make it a habit of tack welding the pickup on as well.
Thanks guys!
So, how quickly must this be taken care of?
I understand that having a pick up tube sitting in the bottom of the pan isn't good.... is this something that needs to be done immediately.... like tomorrow? Or can it wait a bit?
Only reason I am asking is I just had surgery 3 weeks ago and I'm not allowed to do anything for the next 6 weeks.
Thanks guys!
If you have a strong enough magnet you could drag it across the bottom of the pan (put a rag between to eliminate excess noise) and see if you hear the pickup being moved
If you buy a canton pan, the pickup bolts into the oil pump housing. I have a mellings select pump with the canton pan/pickup. One word of advice, buy a one piece felpro pan gasket, much easier to use and less chance of leaks. Mine was doing that when i first bought it, drove it around somewhat easy for the rest of the summer and fixed it in the winter. My bro almost **** himself the first time it happened....
If you (OP) do plan to get a high volume, keep in mind that they apparently can suck out pans dry.
