Lucas Oil in...
Lucas Oil in...
an M6, i run it in my automatics & it seems to work good, has anyone run it in there M6s, i'm sure it wouldn't hurt anything & may help it shift smoother.
If you are a believer in Lucas you have done inadequate research.
When I was younger I thought it was good to put gear lube in a manual tranny that called for ATF, lasted a surprising amount of time before bearing failure on one tranny and on another the first gear seized to the shaft effectively dropping the truck to first gear at 60mph and keeping it in first gear only. I thought it was a good idea up till then.
