Larger oil filter
Old 09-14-2008, 04:51 PM
BOLO's Avatar
Default Larger oil filter
Is there any performance/advantage into using a larger oil filter other than adding an xtra half a quart of oil in the crank case?
Old 09-14-2008, 05:33 PM
fergymoto's Avatar
More capacity for debris
Old 09-14-2008, 05:38 PM
k0261886's Avatar
It doesn't add any extra oil to the crank case. The oil stays in the filter when the car is shut off.
Old 09-14-2008, 05:45 PM
leadfoot4's Avatar
There's the slight benefit of cooling, as you have more oil in the system, and it's flowing through the lifter longer, pulling off a bit more heat.
However, in the case of the later Z-28s with the LT-1 engine, the oil filter is about 1 inch from the cat converter, so while heat extraction would normally be a plus, in this case, it's minimized.
BTW, which "large" oil filter are you referring to? The "standard" large filter (PF-35) that holds 1 qt., or the 2 quart, "HD truck" filter?
Old 09-14-2008, 07:15 PM
hashtagBMW
Speed Density's Avatar
The Napa Gold or Wix tall filters are what I use.
The bigger unit allows for more oil and better filtering.
Old 09-14-2008, 07:40 PM
Toronto_LT1's Avatar
PF 35 here.
Old 09-14-2008, 07:59 PM
kinglt-1's Avatar
Fram PH5 here!
Old 09-14-2008, 09:40 PM
Sinister95Z's Avatar
I just use a K&N filter from a early/mid 90's chevy 5.7 truck. It is at least two inches longer than the stocker.
Old 09-14-2008, 09:43 PM
StangeatinZ28's Avatar
a/c delco pf 454 here
Old 09-14-2008, 09:47 PM
BOLO's Avatar
So, as most of you mentioned, a larger filter has it's added benefit. Thank you, all.
Quick Reply: Larger oil filter
