Going to track later, guess my times
I should be heading to the track later today hopefully, so tell me what you think I'll run
6-speed
355 w/ GM 847 cam, about 10.85:1 compression
heads are 99% stock, they were very lightly hand ported but not gasket matched or anything
bolt ons (exhaust, cold air)
MadZ mail order tune
4.10s
Nitto drag radials on a pair of salad shooters
6-speed
4.10s
6-speed
4.10s
6-speed
4.10s
what injectors
1.5,1.6 rockers
throttle body
tires
altitude,temp,humidity,barometric pressure.
i would say low 12s w/traction depending on driving skillzz
If you leave the line around 2,500rpm and do not spin a 2.0x is going to happen. Be carefull going into the upper 3,000rpm range these rear ends don't like it with an m6. I've broken 3 already...
Which one are you running? I know what you mean though. It may take a pass or two but the best way to preserve these things is after you second stage bring the clutch up to the point to where it is damn near about to roll forward but don't go to far or you will redlight. That will put you at the friction point and allow you to ride it out. It's kind of tricky at first though...
It's a Powergrip HD
Someone else told me to get the clutch just up to its initial grab point and hold my foot on the brakes as well (like you would when starting a brake stand), because that well take out any driveline "slack" and make the launch less harsh. It makes sense to me but it seems like it would be easy to screw up.
But it's very possibly to do, I do it all the time. You just use your right foot, heel on the brake, toes on the gas - clutch in with the left foot, then punch the gas with your toes, drop the clutch, and then you can move your left to the brake and the right to the gas.
Silly automatic drivers
edit: That would be for doing a brakestand, but the same technique applies to holding the car still with the clutch out slightly while being staged
