wont start no spark
Old 09-19-2008, 05:03 PM
daniel6718's Avatar
Default wont start no spark
car was driving fine. stopped at a light took off made a turn and it started to spudder for about 30 seconds then died...
first though was gas...either out or fuel pump but both are fine....
we checked the coil according to shoebox and all was fine...
i replaced the coil with another same problem
replaced the pcm same problem
checked and changed out the opti harness
still have the same problem, any other ideas?
Old 09-19-2008, 09:11 PM
daniel6718's Avatar
icm...
Old 09-20-2008, 02:38 AM
jarretthise's Avatar
you changed everything besides your opti?? sounds like your opti man..check your coil by pulling off the wire from your opti and leaving the other end on your coil... is that how you checked your coil??
Old 09-20-2008, 02:39 AM
another thing could be is the plug wires or plugs... check and see if your plugs are fowled out..is it getting fuel??
Old 09-20-2008, 02:40 AM
and yes your icm could cuase it too..
Old 09-20-2008, 03:07 AM
hashtagBMW
Speed Density's Avatar
Thats what my new setup started doing after a few startups, it ended up being the ICM.
Good luck.
Old 09-21-2008, 08:07 PM
Fast93Z's Avatar
could having a bad opti cause the pcm to not send a signal to fire the coil
Old 09-21-2008, 10:41 PM
daniel6718's Avatar
i found out it was the icm when i posted that...thanks guys....
Old 09-21-2008, 10:57 PM
hashtagBMW
Good deal, thanks for updating for reference to others.
Old 09-21-2008, 11:17 PM
good deal man...glad ya got your car running...
Old 09-21-2008, 11:46 PM
TwoFast4Lv's Avatar
Damn i have yet to see one of those go out but they are getting popular
Old 09-23-2008, 01:52 PM
daniel6718's Avatar
me neither...i immediately though since it spuddared it was fuel problem
once i found out it wasnt and it had no spark i was confused...
i knew it wasnt the common opti rotor problem...so i checked shbox site...all was good..i swapped coils and ohmed the coil wire no problems there...i then knew it was the icm, swapped it with another and it fired
Quick Reply: wont start no spark
