Car Is Smokin With No Codes ??? Help....
the car is smokin from the exhaust alot with no codes coming on. smells rich and smells like oil. my brother is going to do a compression test and some other stuff . im just wanting to no what else we should check for ?
i guess it can be a regulator or something he says or maybe a ring since the problem happened after i used some juice.
dumping fuel out exhaust not normal even smoky when i get on it it will dump fuel, smell like fuel and have a light tannish color smell when i get on it hard like 1/2 thottle, no oil is the bumper or on the ground just fuel.
fuel psi is at 40 when at oper. temp
with vac line disconnected it stays at 40psi even ?
psi regulator isnt leaking fuel out the vac line
nor do i smell gas at that line
no leaks found anywhere from the rail/injectors
pulled out cyl # 1 and 3 no fuel on plugs at all and checked compression on those 2 cyl.
175 at cyl 1
180 at cyl 2 with 6 cranks
there are no codes at all.
what can this be.
175 at cyl 1
what can this be.
