new set up
new set up
well i finally just sat down today and put my setup down on paper to take a real good look at it so i figured i would share and see what your opinions are.... Here ya go
Motor:
Ported heads (upgraded springs and valves)
matched intake
custom cam
30lb injectors
ac and smog delete
pacesetter lts
x-pipe into true duals
58mm tb
new plugs, wires, opti
cai
1.6 pro magnum rr's
spray after a while
Suspension/Chassis:
subframe connectors
6 point cage
draglite slicks and skinnys
tubular k + a-arms
eibach drag launch kit
new shocks and sturts
drivetrain:
3500 stall
1/4 mile time - ???
here is my current setup
o/r y pipe
flowmaster cat-back
2500 stall with built tranny and shift kit
3.73s
1/4 mile time- 13.5 @105
Motor:
matched intake
custom cam
30lb injectors
ac and smog delete
pacesetter lts
58mm tb
cai
1.6 pro magnum rr's
spray after a while
Suspension/Chassis:
subframe connectors
6 point cage
tubular k + a-arms
drivetrain:
3500 stall
1/4 mile time - ???
o/r y pipe
flowmaster cat-back
3.73s
