Nitrous help?
Nitrous help?
This is the first time i have ever considered sprayin a car but i just read somewhere that the stock LT1 PCM is to slow to recognize t nitrous through the maf with a dry kit? what kinda truth is there to that?
what do you think of this kit? http://www.nitrousoutlet.com/catalog...roduct_id=3204
I never really understood the purpose of a window switch. what are some of the benefits and is it a most for that kinda setup? yea but i goin to get the plugs?
Guest
Posts: n/a
I would not run a nitrous kit without a window switch.
It prevents low rpm activation and will shut the nitrous off in an "over-rev" situation. This can be caused from tranny/clutch slippage, drive line breakage, miss shift, etc. You can also use a window switch to shut the nitrous off in between shifts to save transmission wear also.
Guest
Posts: n/a
.........you beat me to it
I run Nitrous Outlet's Plate Kit! It's great and the results are amazing! Anything you buy from them is great. And the Service is Some of the BEST i have ever worked with!!
OOHH.... cant wait for mine! lookin like the complete lt1 plate package is gonna work great for my ride
http://www.nitrousoutlet.com/catalog...roduct_id=2809
