what plugs for my 396 LT4?
Old 09-29-2008, 11:20 AM
WHITEBOY_ZACH's Avatar
Default what plugs for my 396 LT4?
thanks
Old 09-29-2008, 11:34 AM
fergymoto's Avatar
What is the compression ratio? Depending the motor may like NGK TR55s or TR6s
Old 09-29-2008, 11:48 AM
sorry i was lookin for my papers, i really dont even remember. its got flat tops , built for a 400 shot.
its pretty high
but i will NOT be spraying this year.
Old 09-29-2008, 12:02 PM
LS1 SPEED's Avatar
hard to know with out specifics
I would say a 6 or 7 if high compression for NA.
Old 09-29-2008, 12:06 PM
fergymoto's Avatar
My ~11:1 stock bottom end setups like TR55s, but my 12.2:1 383 liked TR6s. Here's some good articles that will help you determine heat range and everything else too.
http://www.dragstuff.com/techarticle...ead-plugs.html
http://www.dragstuff.com/techarticle...ark-plugs.html
Old 09-29-2008, 01:25 PM
hashtagBMW
Speed Density's Avatar
Well considering you bought Brett's old motor you need a gasket style plug. I would start out with some AR3923's on that, maybe even a 3924.
Start cold and work you way up, dont start hot and work cold you will end up hurting things.
AFR heads require gasket plugs, just like LS1 motors.
Old 09-29-2008, 01:34 PM
i was hopin you or he would chime in thanks
Old 09-29-2008, 04:28 PM
hashtagBMW
Those autolites cross reference to like 4 other manufacture's plugs. NGK, Champion, etc.. so if you have a prefernece that you'd like to run with you can.
