Exhaust Help
Old 10-03-2008, 01:44 PM
transamws6_97's Avatar
Default Exhaust Help
I've been fighting stupid exhaust leaks with these band clamps...had one on the drivers side collector and got it fixed. Now I have one on the passenger side and I can't seem to get rid of it...I really don't want to get a flange because that'll kill my ground clearance but these band clamps are not cutting it...10 bucks a pop and they only work 90% of the time and then as soon as you loosen one to take a piece of exhaust off it will never ever seal again.
Old 10-03-2008, 01:49 PM
jarretthise's Avatar
have it welded!!
Old 10-03-2008, 01:57 PM
i cant have it welded its duals over the axle and i have a bmr crossmember which is weld in so there would be no way to remove my exhaust if i ever need to work on something under there
Old 10-03-2008, 02:00 PM
i see...well im from crawfordsville which isnt too far from you....maybe i could come up and check it out and help out and see what can be done other wise
Old 10-03-2008, 02:24 PM
AChotrod's Avatar
Use muffler mender around the leaky spots then reuse your bandclamps and clamp them as tight as you can without smashing the pipes
Old 10-03-2008, 02:38 PM
the_merv's Avatar
I have the Stainless Band Clamps that you get at Napa, I've re-used them several times without any problems.
Old 10-03-2008, 02:50 PM
1redta's Avatar
Default re
I put some of the copperseal gasket stuff inside of my band clamps, v-band connecters, and wifes mouth, all holding great
Old 10-03-2008, 03:17 PM
the_merv's Avatar
Originally Posted by 1redta
..and wifes mouth..
Old 10-03-2008, 03:30 PM
AChotrod's Avatar
LOL! I have reused some SS one from lee auto parts and never had a problem either
Old 10-03-2008, 06:27 PM
kinglt-1's Avatar
High temp rtv copper gasket sealant is your best friend! Put a nice bead of it on the inside of the clamp before you put it on and impact the clamp bolts and you should be good!
Old 10-04-2008, 04:29 AM
gatorhead's Avatar
Just run open headers dumdumdum!
Old 10-04-2008, 01:43 PM
the_merv's Avatar
^^Bad O2's FTL...
Old 10-04-2008, 03:23 PM
multmigs's Avatar
HOLY SH(*&^ this guy is my hero!!
Thats the best thing I've read on a internet forum in months.....
Seriously though poster you are doing something wrong or have a bad clamp, I've used the dynomax band clamp avail from Summit, Napa etc for years they are the best thing if you have to pull stuff apart, perhaps a bit O' copper RTV as suggested??
Old 10-04-2008, 05:30 PM
gatorhead's Avatar
^^Bad O2's FTL.
Meh he don't need no stinkin o2's anyways lol.........btw that reply earlier was my way of sayin hello to him
Quick Reply: Exhaust Help
