Pilot Bearing removal
Old 10-06-2008, 07:09 PM
Fast93Z's Avatar
Default Pilot Bearing removal
i wanted to know how to get the old bronze pilot bearing out of the back of the crank ive tried using a screw driver but its almost as iff it is siezed up in there and wont move all responses are greatly appreciated
thanks
Old 10-06-2008, 07:30 PM
FlamingChicken's Avatar
there is a removal tool but if you cant find one packing the hole with grease usually works. you need something that is roughly the inner diameter of the bushing/bearing and you smack it. its like a hydraulic press
Old 10-06-2008, 08:16 PM
Chuckels's Avatar
Use the hydralic method used it twice and works well. I used a grease gun to shoot the hole full then use the alinment tool and hit it a few times, then it started to push out.
Old 10-06-2008, 08:28 PM
Fast93Z's Avatar
ive tried that but it seems as if it is siezed in there and it doesnt want to come out
Old 10-07-2008, 12:10 AM
Village Troll
SS RRR's Avatar
You can get a slide hammer from Autozone and use one of the claws as well. You may have to reem the bushing out a bit to get the claw to fit.
Old 10-07-2008, 06:38 PM
Fast93Z's Avatar
ive tried almost everything im almost fed up with it to the point where i want to use a hole saw and drill the bitch out
Old 10-07-2008, 06:43 PM
fergymoto's Avatar
The tool Auto Zone has works really well. Did you try it?
Old 10-07-2008, 06:59 PM
csjta2's Avatar
I've been thru the same ordeal
This is what I did, I took a carbide burr and cut the bushing down on one side pretty far, you have to be careful not to get into the crank, but if you take your time it will work. Once I did this i just used a small 3 jaw puller and it pulled right out.
Before that I broke 2 2 jaw pullers and 1 3 jaw puller that I got from the Snap on man, he replaced the broken jaws and that's when I did the carbide burr trick
Even tried the grease trick wouldn't move it at all
Old 10-07-2008, 07:01 PM
ClovisAutoMotion's Avatar
Just go rent the tool, spend the few bucks to do it right it'll be worth the time saved over screwed around with it
Old 10-07-2008, 09:06 PM
formulabrandon's Avatar
guys its eaier and cleaner to use bread. take a couple slices of bread take small bits and ball them in ***** that will fit in the hole. keep stuffing it full and use a bolt or punch like with the grease. keep adding bread till it pops out, and believe me it will pop out. dont use a bur yo could easily screw up the crank.
Old 10-07-2008, 09:07 PM
this works better because bread is solid not a liquid. only in kentucky will u find a trick like this
Old 10-07-2008, 09:12 PM
Vertigo's Avatar
Been there more than a few times. If you haven't already messed up the back edges to where the puller can't grip the edges your best bet is to use a slidehammer/puller. Otherwise your pretty screwed... Since its brass what I did at this point was to take a tiny tiny hacksaw and cut threw it in two places 180* apart then use a slide hammer!! It will take some work and the good news is this will be the worst part of the whole job. Also make sure you don't need to install shimms before putting that clutch in.
Old 10-07-2008, 10:33 PM
Fast93Z's Avatar
i bought it today ill let you guys know how it comes out thanks for all your help
Old 10-08-2008, 07:37 AM
DAVE00's Avatar
I tried bread, grease and even wet toilet paper as some suggest, but none of them worked as that sucker was pretty stuck in there. The only way was the slide hammer for me and it took two wacks and it was out. Did take a mallet to get the jaw puller in and hooked behind the bearing, needle bearings went everywhere, but oh well it was coming out anyway. Good luck!!!
Old 10-08-2008, 05:32 PM
Fast93Z's Avatar
i finally got it out i used a wheel bearing slide hammer and it took two blows and it came out putting it in took a hammer and a socket
Quick Reply: Pilot Bearing removal
