LE1 guys, you may enter
Old 10-08-2008, 09:18 AM
whammer33024's Avatar
Default LE1 guys, you may enter
just wondering what the guys with LE1 package are running for injectors. i'm trying to get all the parts bought before i send my heads off to lloyd for porting.
Old 10-08-2008, 09:29 AM
StealthFormula's Avatar
Some red top 30# SVO's would work just fine, thats what I run with my LE2's.
Old 10-08-2008, 09:31 AM
LTBANDIT's Avatar
What does the LE1 package have to do with it? oops was thinking 1LE...
my bad! i'll shutup
Old 10-08-2008, 10:02 AM
Z-RATED94's Avatar
As Stealth said, the 30# red tops would probably be the way to go. I use those too, in a set-up close to his.
Old 10-08-2008, 10:28 AM
cool, thanks guys. red tops it is! anything special i need to look for when buying them?
wrd1972's Avatar
I have the red top 30# injectors and they hit 92% DC at WOT. This is not good.
I have purchased some Racetronix 37# injectors and they will go in soon. I just need a decent understanding of how to tweak the tune for the short run till I can get back to the dyno.
Old 10-08-2008, 10:31 AM
Fixxer99TA's Avatar
Go with at least some 36s unless you like running maxed out injectors and loosing HP you could have had....
Old 10-08-2008, 10:34 AM
Formula350's Avatar
my bad! i'll shutup
LOL Me too!
Old 10-08-2008, 10:55 AM
i'll max them out even with the le1 package? well i certainly don't want that, lol
Old 10-08-2008, 11:46 AM
They should definetly not be maxed out with that package, you figure you will be in the 380rwhp range thru the auto. Even talk to Lloyd he will say 30's will work fine.
Old 10-08-2008, 12:04 PM
AChotrod's Avatar
Im working on my LE2 heads with 230/236 LE2 custom cam and LE3 intake.
Lloyd just told me to get Delphi 37lb injectors.
Originaly said svo 30# redtops would be fine, but by the time we were done with my set up(I switched to the hotter cam, patriot springs and LE3 intake) the 37s will be needed.
Old 10-08-2008, 12:53 PM
k cool, i think i'll just go with the 30's. thanks for the responses guys!
Old 10-08-2008, 02:38 PM
wrd1972's Avatar
See post #6.
Old 10-08-2008, 02:45 PM
LTBANDIT's Avatar
Originally Posted by wrd1972
See post #6.
but you have le2 heads and 417 rwhp which is pulling alot more air... i would think the red svo 30's would be good enough fo 360-380 rwhp...
your gonna have to get a dyno tune anyway... so for the le1 i would just get a used set of 30's and go from there...
Old 10-08-2008, 02:48 PM
ulakovic22's Avatar
I personally ran 30lb SVO's. If you have the chance to get something between 30lb-42lb for cheap used in the classifieds you will be good to go. Anything in that range can be tuned to work with your combo just fine.
Old 10-08-2008, 02:49 PM
LTBANDIT's Avatar
wouldn't a mail order tune be close enough to get you to the dyno?
Old 10-08-2008, 02:51 PM
ulakovic22's Avatar
If he already has a good dyno tune he should be able to change the injector constant and that should be good enough.
Old 10-08-2008, 03:55 PM
well i don't have any sort of dyno tune. ion did a mail order for me after i installed headers, gears, and stall
Old 10-08-2008, 04:28 PM
See post #6.
You have 412rwhp where he will be a good amount less than that...Lloyd's site states 360rwhp for LE1 heads/cam plus the poster has a Stalled Auto so no matter what he pulls even if he does more than expected like 380rwhp, he will be atleast 35rwhp less than you. Obviously more injector wont hurt but 30's will work for his power level, if he can get some 36's or 37's for a better price (not likely) then def go for it.
Old 10-08-2008, 05:00 PM
that's kind of what i was thinking stealth, thanks for your input. i'll keep my eyes open for some 36# or 37#, but i have a feeling that i will be happier with the price of 30# ones and they will do what i need!
Quick Reply: LE1 guys, you may enter
