alternator mounting options?
Old 10-08-2008, 11:10 AM
ninety4three4's Avatar
Default alternator mounting options?
i am dropping my LT1 into my 76 and the only accessory it will have is the alternator as i have a manual box so i need som belt/mounting options for the alternator, i would like to go with around a 100 amp unit, let me know what you guys are using, thanx
Old 10-08-2008, 11:55 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
will something like this work???
that is the alt. relocation kit from Madman------------------------------------------------->sponsor list
Old 10-08-2008, 11:59 AM
Racin96ss's Avatar
If it does I will recommend using the Speed inc bracket...I have an SJM bracket and I have not had good luck with it. I will be switching over soon.
Old 10-08-2008, 12:33 PM
19mike84's Avatar
i have that same bracket in the pic, it works great. i bought it from madman
Old 10-08-2008, 03:50 PM
so speed inc and madman, sounds good now do these kits come with a new belt or do you need to supply that yourself? also what is the amperage on the stock 94-up alternators?
Old 10-08-2008, 04:37 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the Madman kit comes with a new belt....not sure on the stock alt. amp rating...I think it is 140amp tho'
Old 10-08-2008, 09:44 PM
LS1 SPEED's Avatar
billet bracket, quality hardware and belt included ( must note UDP or stock diameter)
$234.99 polished
$199.99 satin
few pics from page 8>>>
https://ls1tech.com/forums/showthrea...ocation&page=8
Old 10-09-2008, 08:18 AM
impaled's Avatar
i would look into March Performance. i have their pullies on the IROC (crank, water pump, and alt only) and i have no complaints. they make a lot of brackets for different applications and i was very impressed with their fit and finish.
Quick Reply: alternator mounting options?
