Way to good at trans removal
I am sure I am not breaking any records, but me an my buddy have dropped my t56 so much, we can do it in 1 hr 15 min. Air tools F...T...W. FU autoword changer.
4 jackstands. The bottom of the car body about 14 inches off the ground. Air tool and about 2 feet of extensions keep your arms from dying. Take the crossmember off to have near unlimited access to trans bolts. Also have a buddy use a strap around the trans and hold it up from the shifter hole to keep it from rotating around.
I did mine (for the 1st. time) WITHOUT air tools & it took a good 2.1/2 hrs., thats at least a good 45 minutes os f%cking with the Ory to get it off, these trannys are easy, consoles somewhat of a pain but not too bad, the engine sits pretty good on its own & is fairly "N" balanced, but it never hurts useing a small bottle-neck jack for support. Just use 4 big jack stands & get it up so its comfy for you to slide underneath.
Only problem I have is that top bolt on the passenger side, my hands are far to big to get up there to line the socket on it. Other than that I think it took me 2 hours to get it out when I put the LS7 clutch in.
I usually put the front of the car up on ramps, with the ramps backward (sloped side pointing toward front of car). This frees up max space under the car, whereas jackstands up front always seemed to be in the way.
For the rear, just regular jackstands under the frame rails.
I'm just kidding around, I know these clutch systems aren't the greatest design in the world. I'm already considering a Tick Adjustable Master... just need to allocate some funds after just spending on heads...
